Old 28th September 2008, 09:04 PM   #1
guycom is offline guycom  United States
Default Brian gt chip amp power supply?
Hi, Looking for some help. Power supply is done using a centertap 3wire output transformer with help from the picture with diod reconfig. I am getting 17.8 volts output unloaded with no light from the led. Pulled and rotated led to change polarity no light. As always thanks for you help,
Guycom
Old 28th September 2008, 09:27 PM   #2
Banned
LED is dead if you have voltage at its pins and no light either way.
w
Old 28th September 2008, 09:32 PM   #3
I understand. Are there different values for leds?
Thanks Again,
Guycom
Old 28th September 2008, 09:35 PM   #4
I am reading .3 volts dc at the led.
Guycom
Old 29th September 2008, 09:57 PM   #5
Banned
The LED is probably dead short-circuit.
LEDs run RED ~1.2 -> 3.6V BLUE depending on colour and how hard driven.
Take the LED out of circuit. Measure the voltage at the pads. You should see the full supply voltage or at least a substantial voltage depending on the exact circuit. If this is the case the LED is definitely dead, if not you have an open circuit somewhere.
A small lithium button cell is good for quick testing LEDs without a resistor. They can drive even a blue LED, but cannot deliver enough current to destroy.
w
Question about CT transformer and Brian's Rev C power supply board maurycy Chip Amps 9 8th December 2009 09:21 AM
Brian GT chip amp build Questions guycom Chip Amps 5 15th September 2008 10:02 AM
Beautiful power supply! Brian's Chipamp.com danielwritesbac Chip Amps 34 28th January 2008 04:44 AM
Brian GT Gainclone Watts/Ch & Power Supply lgreen Chip Amps 5 14th April 2005 07:04 PM
Brian GT NIGC, Power supply voltage kanaddict Chip Amps 12 24th November 2004 02:28 AM
Page generated in 0.07558 seconds (73.29% PHP - 26.71% MySQL) with 10 queries
