| Chip Amps Amplifiers based on integrated circuits |
I'm looking for a method to remove abit of audio hiss. if i were to use a low pass filter what would be a suitable cut off frequency ?
I know this is abit of an application specific question but are there any rules of thumb to get me started. |
#2 |
hiss, as in noise? if you can hear hiss, you dont want to filter it out as this would be in the audio frequency band. Your options are down to reducing the noise for example by lowering the gain, and using lower value (less noisy) resistors in the audio and feedback path.
#3 |
Banned
Enzo is right.
If you can't get rid of the hiss by changing the balance of any volume controls in your system, you have little option but to modify or replace part of the system, probably the power amp or preamp if it is separate. An average MP3 or CD player should have virtually imperceptible noise. w |
#4 |
Thats a very good point
However what is the realistic range of music, I'm sure it doesn't range from 20Hz to 20KHz Also is there any benifit in removing any higher frequencies (say above 20kHz) so as to remove them (almost) from being amplifiered in the later stages. |
#5 | |
Some listeners like the super tweeters,so it's up to your hearing if you want to amplifie the higher frequencies.
xxx I should correct my spelling xxx |
| Hiss but no hum... | RockysDad | Tubes / Valves | 13 | 5th April 2009 05:35 PM |
| Hiss in my P3a Amp | blap0220 | Solid State | 15 | 1st June 2007 01:52 AM |
| Pre-amp hiss on 1 channel | bulgin | Solid State | 1 | 5th August 2006 01:04 PM |
| Can jitter cause hiss ? | percy | Digital Source | 2 | 21st April 2006 04:27 PM |
| hiss | jaudio | Chip Amps | 21 | 6th March 2005 05:02 PM |
| Page generated in 0.08791 seconds (78.76% PHP - 21.24% MySQL) with 10 queries |
