| Chip Amps Amplifiers based on integrated circuits |
#11 |
Hello Ted,
Does your preamp make any noises on switch off as well. It's a very basic circuit is this. How about adding a diode to the IC supply and cap to suit, such that the supply to the 555 collapses immediately on switch off. |
#12 |
Doesn't quite read what I mean
I mean have the supply to the 555 via diode from the AC of the tranny, maybe using CMOS timer and simple R+C+ zener.Delays should be foolproof in that it cannot be confused by a mains interupt etc. You want it to mute instantly and go through it's full "start sequence" everytime
#13 | |
You could switch both the power rails but just supposing one contact of the relay sticks and you turn off just one rail?
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#14 |
That would be the same thing as a fuse blowing only on one rail.
I am coming round to putting it at the buffer output as it makes life easier, and whether it makes and audible difference ........... i like the idea mooly as on power down the transformer will be the quickest to degrate, before the caps degrate and make a small pop on the speakers the relay will have latched (maybe?) and block any signal. |
#15 |
I find that circuit acts fast enough to stop turn-off clicks anyway!
#16 |
fit the mute to the pre-amp output. Use a relay to ground as Nuuk and the others have already told you.
Arrange for delayed on and instant off. If you want you can also add a mute the the power amp input, again with delayed on and instant off. Finally, you can fit another relay to the speaker output of the power amp. This is the only one that has signal through the contacts while operating.
regards Andrew T. |
#17 |
As a matter of interest would this circuit suit the Uno active pre from DD?
http://myweb.tiscali.co.uk/nuukspot/...clonepre2.html I see it's been tested with the buffer circuits but there's no mention of the Uno. I thought it better to ask than to have to stamp the flames out. John
SWMBO's stuff http://www.wowthankyou.co.uk/names-in-lights |
| B+ time delay relay | cbutterworth | Tubes / Valves | 24 | 31st August 2011 01:53 PM |
| Suitable relay for delay cicuit | Nuuk | Chip Amps | 61 | 11th January 2009 02:47 PM |
| on/off thump - use Time Delay Relay ? | redrabbit | Everything Else | 0 | 29th June 2008 03:01 AM |
| Delay-Off relay | peace brainerd | Parts | 7 | 12th May 2007 04:14 AM |
| Time Delay Relay Tubes | cadman | Tubes / Valves | 8 | 17th December 2002 05:25 AM |
| Page generated in 0.08775 seconds (84.72% PHP - 15.28% MySQL) with 10 queries |
