Another DC servo question.
Old 20th September 2008, 12:51 PM   #21
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Originally posted by Mooly
You need to measure these with a low pass filter on your DVM. Say a 10 k and 1 mfd. There could be a lot of HF "rubbish on the outputs which confuses things.
Can I have my dinner now please
Dinner ? At this time? Are you in Japan?
Anyway, bon apetite..
Best regards,
Ozgur
Old 20th September 2008, 12:53 PM   #22
Dxvideo's Avatar
Originally posted by AndrewT
http://www.diyaudio.com/forums/showt...50#post1283350
for a fuller explanation of the issues.
Of course..
The old topic! I will build a DC Servo, sooner or later!
Best regards,
Ozgur
Old 20th September 2008, 12:54 PM   #23
Mooly's Avatar
As Capain Mainwaring would say " Ohh, haven't got time for all that now "
It's dinner time !! Hungry!! Need feeding !!
Old 20th September 2008, 12:55 PM   #24
Mooly's Avatar
Lunch then
Old 20th September 2008, 01:00 PM   #25
Dxvideo's Avatar
Bon appetite again..
I am going to home now, for a lunch of course.. I will measure my OPAs DC offset (with inputs shorted) after the luch and will discuss the potential potentiometer events with that offset..
See.
Best regards,
Ozgur
Old 20th September 2008, 04:31 PM   #26
Dxvideo's Avatar
My OPA s output is 0.1mV... Without offset trim and while inputs shorted.
Does it cause any potentiometer harm in long term?
Best regards,
Ozgur
Old 20th September 2008, 06:15 PM   #27
Mooly's Avatar
No problem at all ? If you null it even that will reduce to zero, but be careful. It's not always straightforward measuring such things, and I would again use a low pass filter on the output to get a "truer" reading.
Does your meter actually read 0.000volts with the probes shorted ? If you swap the meter leads round does it show -0.1mv or something different
Old 20th September 2008, 06:38 PM   #28
Mooly's Avatar
Mad thoughts as you do, not just from todays posts but going way back.
Regarding power amps -- have the error signal fed to a sample/hold circuit that only operates at switch on for a minute or so and then say every 5 mins after that, just for long enough for a new error voltage to be aquired. Problems, well I suppose if there were significant drift of the offset then each time it corrects that could be audible.
Captain Mainwaring again " Your getting into the realms of fantasy now Mooly "
Next ? (Back to the preamp now) Use the output of the servo to correct the OPA via it's offset null terminals. That could interesting, perhaps setting a deliberate error up on one pin and correcting via the other, or perhaps some Opto scheme.
But I think with 0.1mv untrimmed we won't bother today.
It's Tea Time -- and not a moment too soon
Another DC servo question.Hide this!Advertise here!
To use DC servo or not? jaycee Solid State 42 8th December 2014 09:19 AM
DC Servo question... Dxvideo Chip Amps 135 12th October 2013 01:59 PM
DC Servo question Dxvideo Chip Amps 27 15th July 2008 01:01 PM
Copyright ©1999-2017 diyAudio
