| Chip Amps Amplifiers based on integrated circuits |
This is a very little amp project -my first one- with a TEA2025 chip. I know isn't a hifi chip but I'm really learning from it: good for next bigger project. I have a nice little enclosure, my circuit build on a stripboard, an external SMPS (9AC).
Power socket on amp enclosure is a dc one. Rectifiers, filter capacitor and regulator (7809) are part of the circuit, inside the amp enclosure. As the SMPS is double insulated I think it don't need safety earth connection to chassis. Then my actual problem refers to grounding. I'm planning a buss grounding and I wonder what could be a correct way to do it: Connection to chassis: from ac socket through 0,01 uF capacitor. or or I read a few post and other webpages but honestly I need help It could be that all these options are wrong... Thank you in advance |
#2 |
not much help but why have you choosen buss over star grounding ?
#3 |
Isn't easiest? Star ground is ok for me, but my doubts remain...
#4 |
i would have thought star grounding is easier.
i found this article on nelson pass's site usefull: http://www.passdiy.com/pdf/articles/ground-loops.pdf after reading it i sorted my amp and i now have no hum
#5 |
Thank you I'm printing it.
| Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... | EchoWars | Solid State | 37 | 3rd August 2008 08:50 AM |
| twisted pair signal, source selector and ground buss??? | cbutterworth | Tubes / Valves | 2 | 30th March 2007 07:39 AM |
| Best way to connect 6ga wire to buss bar? | Zero Cool | Everything Else | 31 | 19th January 2007 11:07 PM |
| LM3875 kit grounding, optimal grounding for separate amps and psu? | findog | Chip Amps | 9 | 16th May 2005 09:27 PM |
| Brass Buss Bar | kilowattski | Solid State | 6 | 12th October 2003 07:06 AM |
| Page generated in 0.06924 seconds (74.68% PHP - 25.32% MySQL) with 10 queries |
