| Chip Amps Amplifiers based on integrated circuits |
i got some lm1875 chips.i want to play different.is anyone running this poweramp as opamp?how about its sound?
#2 |
it might make a nice headphone driving opamp.
Maybe even convert it to run in single ended ClassA for the lowish current that high impedance phones draw. Try 45 to 60mA for 64ohm phones.
regards Andrew T. |
#3 |
I guess you have to use at least gain=10.
But maybe there is some TRICK to use less gain, as preamp, and still keep LM1875 100% stable. To have gain=10, for LM1875 as Powerful Pre Amplifier is maybe not any problem. Pre Amplifiers can often have x4 - x10 voltage gain. Same as +12 dB to +20 dB
lineup |
#4 |
thank u
im working on it then,will post the result soon. zang |
#5 | |
You should carefully study the datasheet
Application Hints Eventhough LM1875 is fairly easy to use, there are some things that can go wrong, if we are unlucky. Read this part and onwards. Quote:
You may read his article here: 20 Watt / Channel Stereo Power Amplifier Rod Elliott - ESP (From Design Notes from National Semiconductor) http://sound.westhost.com/project72.htm
lineup |
#6 |
If you use LM1875
as one very, very powerful pre amplifier, you may use two switchable output jacks. > One output for RCA phono stereo to connect to any Power Amplifier. > One HeadPhones output jack Because LM1875 will drive any HeadPhones perfectly. Probably with True Hi-fi, High Fidelity performance. It is one piece of cake, for one chip designed to drive 8 Ohms speakers. Lineup audio amplifiers forum .
lineup |
#7 | |
| LM1875 PCB, Which To Use | Paswa | Chip Amps | 238 | 1st November 2011 12:02 PM |
| Preamp for LM1875 | tom91 | Chip Amps | 3 | 26th July 2009 03:08 PM |
| lm1875 | siemensc65 | Chip Amps | 4 | 23rd May 2006 03:28 AM |
| Lm1875 | soundNERD | Chip Amps | 14 | 12th October 2003 02:26 AM |
| Page generated in 0.09805 seconds (77.94% PHP - 22.06% MySQL) with 10 queries |
