| Chip Amps Amplifiers based on integrated circuits |
hi..i have an emu1212m sound card.it has very good audio specifications.there is njm2068opamps in this card...i want to replace a better high current dual opamps..i had a little look at the internet..LM4562 has 40ma output current max..njm4556 has70ma output current but its an old opamp..i want the card to be capable of driving low impedances(70-100)ohms and low noise low distortion..what do you prefer?..thanks
#2 | ||
Would need 20 mA - 30 mA max output (100-70ohm) 20 mA x 100 ohm = 2.0 Volt 30 mA x 70 ohm = 2.1 Volt Most standard opamps we use for audio can do this! Here is one photo series article, when one guy replacing NJM4556 with one absolute killer perfromance Op-amp: LME49860 see this National OpAmp selector WIZARD http://www.national.com/analog/amplifiers This new super opamp, LME49860, has Minimum 30 mA output current. Quote:
It is one normal dual opamp in 8 pin DIP8. And can provide something like 35-40 mA.
lineup |
#3 |
hehe hi lineup..i am using sennheiser hd25 dj headphone..i had m-audio 192 sound card(it has njm4556 +-70ma output for150ohms) it can drive these headphones.and now i have emu1212m(it has njm2068 it has lower distortion but lower output current too).i used lm4562 too..it was not enough for my headphones..i am sure it can drive little headphones not mine..it becomes distorted when i increase the level of the sound..i want to drive directly from sound card by opamps..not wanna use headphone amps..
#4 |
I don't mean to ignore what you're saying, but realistically you're not going to find a high fidelity opamp that is suitable for your application and supplies a high current output. Building a small, separate, buffered headphone amplifier will allow you to use high quality opamps for the gain stages while leaving the current capacity to chips designed for the job.
| CF-Opamp | Onvinyl | Parts | 6 | 3rd April 2006 03:09 PM |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| Opamp Vcc | computeruser | Solid State | 5 | 13th October 2005 03:27 AM |
| Regulate the psu of a power opamp with a similar power opamp? | Franz G | Chip Amps | 34 | 19th October 2004 10:49 AM |
| opamp-amp | petera | Solid State | 5 | 4th December 2001 11:39 AM |
| Page generated in 0.08153 seconds (73.63% PHP - 26.37% MySQL) with 10 queries |
