Which Chip AMP you like most? - Page 16 - diyAudio
Old 12th December 2012, 12:46 AM   #151
danielwritesbac's Avatar
Originally Posted by ClaveFremen View Post
According Mauro Penasa, first My_Ref versions (not published) were TDA based but only with the LM3886 he found the right chip for his goals.
I was referring to unorthodox use of the TDA7293 with IN+ shorted to IN- so that it cannot amplify anything. The TDA7293 would have its predrive disabled and use the LM318 instead (Connect output of LM318 to TDA7293's Pin#11). The result should resemble the schematic at post #148 except with dMOSfet outputs that are cooler running, higher availability and lower cost than the 2SJ/2SK.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 12th December 2012, 07:15 AM   #152
Mooly's Avatar
Originally Posted by csom View Post
.......Just one question, do i need to make six sets of LM3886 or i can use TDA2050 for high-pass section to drive the tweeters?
Best regards,
Som
I would use the same throughout (LM3886)
Installing and using LTspice IV. From beginner to advanced.
Old 12th December 2012, 09:48 AM   #153
Reality first!
ClaveFremen's Avatar
Originally Posted by danielwritesbac View Post
I was referring to unorthodox use of the TDA7293(...)
Now I understand... sorry no experience about it.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 12th December 2012, 02:14 PM   #154
csom's Avatar
Originally Posted by bcmbob View Post
Wish I could take the credit, but the design is from Dario Inserra. I'm just the Senior Vice President of the propaganda department.
Dario wouldn't do it so, I just gave myself the position.
Warm regards, Som
Old 12th December 2012, 02:23 PM   #155
csom's Avatar
Thank you once again Mooly.
I will make 4 amps using LM3886 for now for my current 2 way active crossover setup.
I am reading Dario and Bob's thread simultaneously and waiting as per his advice
Best regards,
Som
Warm regards, Som
what is a chip amp? cadbury8 Chip Amps 27 7th July 2007 09:01 AM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 05:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 02:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 12:43 PM
Hot chip! batkey Chip Amps 1 14th October 2004 12:54 PM
Copyright 1999-2017 diyAudio
