| Chip Amps Amplifiers based on integrated circuits |
#91 |
The solo chip amp is highly sensitive to current, especially at feedback, so here's some dials for you.
Note: Variable resistors made from multi-turn trimpots--solder 2 out of 3 pins together before use, and then you have a 2-pin variable resistor--check with ohmmeter before use. Setup: (LM1875 non-inverting amp--see the datasheet) ♦ The input load resistor is a simple 10k. ♦ The input cap is 2.2u (like Nichicon ES 2.2u and 4.7n polyester bypass) ♦ The NFB cap is 470u (consider 1u or smaller electrolytic for bypass, or a 22n or smaller polyester dip cap for bypass, but don't use polypro). ♦ The 2 amp board power caps are also 470u, and they can be exactly the same model and same bypass efforts that you find attractive for NFB cap. ♦ The feedback resistor is 10k series to 250k and Parallel that 250k with a 100K multi turn trimmer (creating a 72k variable resistor)--total Range of variance is then 10k to 82k. ♦ The feedback-shunt resistor is a 1k series to 2.2k and Parallel that 2.2k with a 10k multi turn trimmer (creating a 1.8k variable resistor)--total Range of variance is then 1k to 2.8k. Adjust: Although the trimmers have been restricted to decent values, please be careful to avoid setting the gain outside the range of 10x to 40x. You'll need to use your ohmmeter between settings. Divide the feedback and feedback-shunt and then add 1 to find the gain setting. These two dials vary both gain and feedback current, and thus a vast variety of differences is possible, and the choice is yours. Reason: Turning a dial could be easier than hours of soldering different resistor values. After dialing in optimal resistor values, we could then replace trimmer arrangement with nearest value ordinary resistor instead. Alternatives: Dialing in feedback settings is not the only way to fine tune LM1875. External compensations can be added for that job. That is doable, but I couldn't possibly explain it. In this case textbooks can be really helpful. Much textbook material for small signal op-amps can be applied to LM1875 since it is a simple op-amp.
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. |
#92 | |
#93 | ||
All of the caps that are located on the amplifier board are important. If there's no other means to test the quality of caps, you can install a sample as your NFB cap and literally eavesdrop on the quality.
♦ Tools & Guides ♦ ClipNipper headroom boost ♦ Parallel LM1875 pt2pt ♦ Easy parallel TDA7293 board ♦ TDA7294 pt2pt ♦ My post has opinion. Last edited by danielwritesbac; 7th November 2012 at 02:34 AM. |
#94 | |
LM1875 is not a new toy for me. I don't expect it to sound like a high end amp. It is not even the chip I have achieved the best system with. But the real problem with my current implementation is probably the input opamp. I have achieved several outstanding chip amp systems, and all are with pure class-A front ends. I choose opamp here so it can become a "benchmark reference". May be I should use B1, or DOZ preamp? My current opamp input stage uses dual-opamp socket (2xopamps in one package). I don't have enough inventory for this. Last night I tried several opamps form 0.3 to 15V/us, and I have to accept that (in that circuit) the best sound was given by an Analog Device opamp with 1.8V/us. While Sanyo Oscon on the feedback path gave cleaner sound, the bass sounds "colder" and I don't like. |
#95 | ||
Well, they're quite good and indeed the quick trip to hi-fi; however. . . Actually, my favorite amplifiers are the wild dynamics Circlophone and also my old TDA7294 (with rather excessive fine tuning). Quote:
However, if you've got the unavoidable urge to stack another op-amp in front of the power op-amp, try nesting/composite topology to negate insertion loss. Instead of reducing quality, nesting/composite topology can make improvements. ah! That also includes more control over the sound of your power op-amp. P.S. Other answer: DOZ is close. I like the very similar MooseFet triode simulator preamp since it is very clear and so easily adaptable to suit a vast variety of personal preferences.
#96 | ||||||
There has been many blind tests around since Gainclone popularity some years ago. The winners have been always the overture series. I wish I could make a TDA7294 to sound good. Because I like the mosfet sound of it. Quote:
First one, is a TEA chip, no more than 2W, driven by a preamp similar to the MooseFet (but better of course). At that time, I have tube amp and several Alephs (So you know that the benchmark is not that "low"). Second one, TDA2009 chip, no more than 3W for 0.1% THD, driven by a preamp similar to DOZ. Another one was not really a "success", LM3875 with triode preamp, with power supply full of chokes. Inspired by JLTi I guess. But chip amps are just chip amps. I do this just for fun because I have the parts scattered all around the house. |
#97 | |
The non-inverting topology allows virtually any Zin value to be adopted and there is absolutely no value in increasing this further. It's the source that may need a buffer. The source must be capable of driving the cable and the Rin that follows. That Rin can and should include RF filtering and should also include a DC blocking capacitor. If you have a vol pot driving a cable expect there to be problems. vol pots cannot properly drive cables. Sort your source and remove the buffers from the front end of the chipamp. There is one exception. Inverting topology Chipamps. These can have a lowish Rin. Few sources can drive these directly. Here a "converter" is a real performance benefit. See Cordell's jFET LTP "converter". |
#98 |
Well, do it.
TDA7294 non-inverting amp: Pair 220u amplifier board power caps and a single 2u polyester rail to rail. 47u (or 68u) for bootstrap 10k for input load resistor 10k for mute (no cap) 22k with 10u timer for standby 60k (120k||120k) for feedback resistor 2.7k for feedback-shunt resistor 220u (or more) for NFB cap 1u (or less!) for input Output zobel is 10n with ~8R Add RF filtering to input cap Use a stiff power supply (20,000u per rail, 3a per chip) Use less voltage than max (under-volt)
#99 |
Nobody mentionned LME498XX chips + discrete outputs.
A choice i prefer when some power is required compared to paralleling plain chipamps. |
#100 |
That proposal is mentioned many times. Maybe it is just not in this Thread.
I never recommend paralleling and/or bridging of chipamps. |
| what is a chip amp? | cadbury8 | Chip Amps | 27 | 7th July 2007 08:01 AM |
| Pre-amp for chip amp | wotsascott | Chip Amps | 23 | 30th April 2006 04:24 PM |
| First Chip Amp | doomsweek | Chip Amps | 9 | 10th May 2005 01:55 AM |
| Best possible 10W from chip amp | Robert_66 | Chip Amps | 14 | 2nd November 2004 11:43 AM |
| Hot chip! | batkey | Chip Amps | 1 | 14th October 2004 11:54 AM |
| Page generated in 0.67505 seconds (100.00% PHP - 0% MySQL) with 10 queries |
