Which Chip AMP you like most?
Old 7th November 2012, 04:34 PM   #111
Jay is offline Jay  Indonesia
Banned
Originally Posted by AndrewT View Post
Sort your source and remove the buffers from the front end of the chipamp.
Originally Posted by danielwritesbac View Post
You've already got an op-amp. Why stack another for quality reduction? The LM1875's gain capacity goes high enough to clip itself even if driven by an MP3 player. Sufficient gain capacity is one of the conveniences of the 25 watt amplifier, and there's no need of a preamp to increase the clipping.
However, if you've got the unavoidable urge to stack another op-amp in front of the power op-amp.
Actually I don't use buffer. It has gain but lower than usual. From practice I observe that the input gain stage is required to sound good.
Options are: high gain power amp, or low gain power amp plus additional input gain stage. I found it was better to set the gain of the power amp lower to lower noise and distortion.
Old 7th November 2012, 04:45 PM   #112
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Lme 49830 is for mosfets outputs
See also lme48910
Speaker Amplifier and Modulator - Mid/High-Power Amplifier - LME49810 - TI.com
lme49811
http://www.ti.com/product/lme49811
Old 7th November 2012, 05:19 PM   #113
bcmbob is offline bcmbob  United States
Just to make sure I'm close to understanding, Will someone download the photo zip, do some elementary hen scratching showing where the driver chip and/or PCB would be placed and post it here. Not looking for a schematic - just a point of reference or insertion. The photo is one of many MyRef mods floating around.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 7th November 2012, 05:46 PM   #114
rsavas is offline rsavas  Canada
Probably want to use a higher voltage for the LM3886. The LM318 is usable, but you may want to use something with less noise, say a NE5534A, change the compensation as well, if you change the OPAMP. Not sure about putting the OPAMP in the NFB loop with the LM3386, what is the advantage of that?
Rick
Old 8th November 2012, 01:30 AM   #115
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Rick
LM3886 and other Overture series contain the Spike system which exacerbates clipping and indeed sounds like a hard clipper to me. This is unkind to outputs and worsens the situation with a slight bit of sticking. Whatever the case may be, just imagine the worst outputs ever. Now, if you enclose this noisy TV power amp chip inside the feedback loop of a small signal op amp (nesting), then the problem is decreased by same proportion of the new global loop. That's automated quality control.
Short answer: Noise reduction (since it is actually predictable, more accurate term is "distortion reduction").
P.S.
The small signal op-amp in this case is run on regs, and the "clean reference" effect is copied to the entire amp via feedback. A similar approach with a discrete amp is to run the input+predrive (or driver chip) on regs or capmulti.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 8th November 2012, 02:50 AM   #116
Thanks for your explanation, Daniel. You certainly have more experience than I using these parts. Has the posted ckt has been built and tested?
Old 8th November 2012, 05:15 AM   #117
The TDA7294 circuit? Yes, it has been in service for several years.
AndrewT helped me set the feedback shunt to correct values for good bass.
The clean form is posted; however, mine is accessorized. . .
I have added the blarebuster accessory to relax female voice for which I have a hearing peak and have added an "unnecessary output cap" accessory (progressive current drive like the JLH) for helping my sealed box speakers at lowest bass, for which I have a hearing dip. I didn't post the accessories because our ears, speakers, rooms and preferences are all different.
With a starting point of a neutral and clean amplifier, it was then inexpensive, and successful to accessorize it.
I think that it gives a unique feature of a chip amp that is pleasant at full blast.
Originally Posted by Jay View Post
BTW, when I said I couldn't make a TDA7294 to sound good enough, I haven't found a schematic that I think will blow away any other schematics from the LM overture series. There have been many blind tests since the popularity of Gainclone, and TDA7294 never won against the overture series (3876/3875/3886). If that will make the statement less subjective.
I've got some opinions and observations on these differences.
SPL preference versus limiter sound:
To me, the difference can be totally explained by limiter type versus usage. With the spike and acutance effects, low volume playback with LM3886 will sound clearer than TDA7294; however, for high volume playback TDA7294's transparent soft limiter won't make you fatigued. So, opinions on quality could differ by SPL preferences. You can use TDA7294 to shove those difficult and/or inefficient speakers. The design that I posted earlier should be quite durable and cool running. For clearer mids at the cost of more forwards, see Mooly's post on "different compensation" and it *may* make TDA7294 sound more like LM3886, and I think that's unnecessary, but the choice is yours.
Power circuit:
1000u amp board caps for LM3886 means you want to stop the shout; however, 220u amp board caps for TDA7294 means you want to wake it up. That is a critical difference. Be sure to give TDA7294 a 220u on V+ a 220u on V- and a single 2u polyester from V+ to V- or else it won't stand a chance in competing with the clarity of a NatSemi overture series. Also, you need at least 5" (or more) of umbilical cable between power supply reservoir to amplifier board decoupling caps. Although LM3886's like all-in-one boards, the same will make TDA7294 go dull, so don't put the power supply on same board as amplifier--Op-amps are sensitive to power circuit and ideal support circuit for TDA7294 is much different than ideal support circuit for LM3886, so please avoid the expectations of rolling. I'm just trying to say that these chips have different needs.
Ebay Board:
If your TDA7294 kit has rectifier, power supply reservoir, and amp decoupling caps all on one board, and if the trace between power supply reservoir to amp decoupling caps is too short, the amp will sound helplessly dull. My unorthodox fix involves cutting the V+ and V- traces to disconnect the power supply reservoir caps from the amp decoupling caps, and then I bridge the cut traces with schottky diodes (or a resistor may work). This is "umbilical cable simulator" patch for dull integrated boards, whereby schottky and/or resistors have replaced the missing umbilical cable.
Of course, for an orthodox solution, we could upgrade the kit to Separate power supply and amplifier boards, and then the length of the umbilical cable (between the two boards) could be varied to whatever you like.
Needless to say, bargain quality tone controls on ebay kits need upgraded with a "tone cancel" switch so you can check out the sound of the amp without the influence of the tone section.
Prior to any fine tuning, we must have a clean head start, else there may be difficult component selection.
Old 8th November 2012, 05:20 AM   #118
Oh. If you were asking about the LM3886 circuit at post 113, that's a MyRef.
There are many of those in use.
Bob was asking how to upgrade the LM3886 circuit to LME498xx with high end outputs.
Old 8th November 2012, 10:08 AM   #119
................. From practice I observe that the input gain stage is required to sound good.................
If this is true, then your gain stage could probably be moved to a better location, because I suspect your Source cannot adequately drive the cables.
It's not the Power Amplifier that needs a buffer/gain stage, it's the Source that needs the gain stage/buffer.
That Source could be a vol pot, or a direct feed from an MP3 player, or DVD/CD player, or etc.
LM chip amps have a gain range. The 3886 is >10 and <50 (not sure of this number since I never approach it), but better performance is generally obtained with gain between 25 and 40.
regards Andrew T.
Old 8th November 2012, 10:13 AM   #120
Originally Posted by bcmbob View Post
.........Will someone ............. do some elementary hen scratching showing where the driver chip and/or PCB would be placed and post it here................... just a point of reference or insertion. ................
take out IC2.
Replace that with the Whole {driver chip and output stage and compensation} using the existing feeds from +IN, -IN, Vcc, Vdd, Output.
BUT, the MyRef has been developed around the 3886. There is compensation between the 3886 and the rest of the MyRef circuit.
That compensation will almost certainly need to be changed/adjusted to get stable performance from the assembly.
regards Andrew T.
Which Chip AMP you like most?Hide this!Advertise here!
what is a chip amp? cadbury8 Chip Amps 27 7th July 2007 09:01 AM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 05:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 02:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 12:43 PM
Hot chip! batkey Chip Amps 1 14th October 2004 12:54 PM
