My 2nd Gainclone.
C5 is far too small. It must be sized so that the high pass action of Ri2 and Ci act as the bandwidth limiting filter.
for 2u2F & 20k use C3>=62uF (68uF or 75uF or 100uF).
for 4u7F & 20k use C3>=133uF (150uF or 180uF). This is my preference.
Add an RF filter to the input.
Somewhere between 330pF and 1nF should match the 1k0 you have for Ri
Well, i already found
Panasonic FC capacitors (2200uf and 1000uf) will order this 2 values so i can compare it.
MUR860 from Onsemi.
not lucky with Caddock, (ar least where im searching). I found some Vishy, are not good like caddock right?
About BlackGates, 47uf value i need to purchase?
what about the brand for Cs1 and Cs2 caps?
