| Chip Amps Amplifiers based on integrated circuits |
So i honestly stolen this design from the www and made a layout.
No point in inventing the wheel again and again. The layout is starting to look nice but i could always use a few more eyes to spot the erros. Schematic. And the layout. What say you all? /JZ
Tala är tiga, silver är guld |
#2 |
That's not bridged.
It is parallel. AND look at the length of the undecoupled power rails! Does that long power ground rail realise low inductance?
regards Andrew T. |
#3 |
AndrewT, Of course it is,, Thanx!
And thanx for commenting Mmm. Well they are not that long, about 30mm between caps and screwterminals, And as you see, they can very easy be made shorter. ![]() Noticed and i,ll fix that in the "mix" Nothing more AndrewT? /JZ
#4 | |
The other power pins are similarly crippled. Do you really need parallel? Change to efficient 8ohm speakers. What about the tolerance of the matching components to allow parallel to work correctly?
regards Andrew T. |
#5 |
Mmm.. you are right, it is abit long. I,ll see if i can shorten it as much as possible.
matching components should,nt be that difficult. I get the feeling that you think the parallel chipamp is a bad idé all in all? It seems to be kind of popular to build /JZ
#6 |
The decoupling can be tacked on the bottom afterwards if needed. I see the power leads are very thin and this goes against the idea of these paralleled to handle more current.
Running between the pins on the footprint of the LM doesn't give much room. Better to move these in order to make them wider. |
#7 |
Thank you MJL21193.
I,ll see what i can do /JZ
| Olle:s first chipamp with LM3886! Board layout? | ollebolle | Chip Amps | 22 | 31st March 2009 01:08 PM |
| PA100 Heat Issues...LM3886 Based..Any Ideas? | MartyM | Chip Amps | 10 | 16th December 2007 11:18 PM |
| Non inverted, 3 x parallel LM3886 schematics and layout. | markiemrboo | Chip Amps | 0 | 6th December 2007 12:42 PM |
| pa100 pcb single sided layout lm3886 | dgaxeman | Chip Amps | 6 | 24th May 2006 01:45 AM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.10750 seconds (68.91% PHP - 31.09% MySQL) with 11 queries |
