My first Chipamp
My first Chipamp
Old 11th September 2008, 03:00 AM   #1
Trooper46 is offline Trooper46  United States
Send a message via AIM to Trooper46
Default My first Chipamp
well after doing a fair amount of reading i purchased a lm4780 kit from audiosector. after sitting around with the kit for some time now i finaly started it tonight. i'm not really all that good with a soldering iron but i did try my best.
has any one built this kit? i am afraid i do not know what cz, rz, and rm are. i could not find them in any of my packets of parts. maybe they are optional? any insight would be great.
also i still am undecided if i am going to run the chips bridged, parallel, or just make 2 stereo amps.
see the pic for whats done so far and the heatsink i plan on using.
Old 11th September 2008, 03:05 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
start with making one stereo
this is the standard and will have less problems/issues
then later you can try bridge/parallel
i also do not know what those cz, rz, and rm are
did you consult The Manual?
Peter Daniel has put together a very good builder instruction called
User Guide or something like that
you can download this PDF from the website KIT page
lineup
Old 11th September 2008, 03:14 AM   #3
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
My first Chipamp Send a message via AIM to Peter Daniel
Default Re: My first Chipamp
You can find more specific info about that particular kit here: http://www.diyaudio.com/forums/showt...565#post636565
Also, LM3875 online user gide is quite useful as well, as both kits are very similar: http://www.diyaudio.com/forums/showt...3&pagenumber=1
Rz and Cz are Zoble parts and I personally don't recommend using them, that's why those parts are not included with a kit.
Rm is mute resistor (10k). It is tiny SMD part and should be inluded with a kit; the amp will not work without it.
For bridged application you need to provide balanced signal to the amp. Parallel and stereo option will work with all standard sources.
Your heatsink looks very good, don't forget to isolate the chip; the yellow plastic strip (inside the schematic) was provided for that purpose.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th September 2008, 03:24 AM   #4
thanks for the quick response. i think i will build this first one stereo. hey that way i can have two amps right!?! so i do not have to source the zobel components, but i do need to install the mute resistor. sounds good. i'll keep this thread updated until i have a working gainclone! once again thanks for the help guys!
Old 11th September 2008, 03:36 AM   #5
Yes, with a stereo setup you will get 4 separate channels from one kit.
www.audiosector.com
Old 12th September 2008, 03:44 AM   #6
board is pretty much done. need to get that led and resistor for it still. i also seem to be running into issues trying to find a suitable transformer. parts express seems to be out of every one that i've heard of people using. they do however have a 250 VA 2x18V. would this be suitable? i'm still trying to push the 60 watts a channel out of this thing.
Old 12th September 2008, 10:35 AM   #7
Redshift187 is offline Redshift187  Canada
Check this graph for power output vs transformer voltage:
http://www.diyaudio.com/forums/showt...92#post1508992
Divide the voltages in the graph (DC) by 1.4 to get the transformer secondary voltage (AC). For 60W into 8 ohm, you need 35V DC. Which would require a 25V transfomer.
Old 12th September 2008, 02:05 PM   #8
thanks, guess im just going to have to wait for 25v secondary toroids to come back in stock.
Old 12th September 2008, 10:50 PM   #9
well its all soldered up, with led and everything, but i had to use a 100k resistor because i didnt have any 62k. hope the led still works. well i guess my question is, is there any way to test the amp before my toroid gets in?
Old 13th September 2008, 01:43 AM   #10
lanchile is offline lanchile  United States
lanchile's Avatar
Well,the only way to test your amp is with the transformer.Be patient and do not rush your work.make sure to check and re-check all connections before you plug it in. You can use a light bulb to be in the safe side.Good luck.
My first ChipampHide this!Advertise here!
My chipamp zymurgn Chip Amps 25 3rd December 2008 06:29 PM
Appropriate chipamp for HT2 paean Chip Amps 11 8th February 2008 09:15 PM
Chipamp with SMP pjpoes Chip Amps 10 23rd June 2007 12:20 PM
chipamp.com renfrow Chip Amps 14 11th August 2006 09:10 AM
FS chipamp and dac eapavant Swap Meet 16 3rd August 2006 06:10 PM
