| Chip Amps Amplifiers based on integrated circuits |
I have used boards from Peter Daniel, but parts and Integrated circuit did not came from Peter. I have assembled and no error, received double check, no shorts or wrong parts.... transistor insulated, and even side screws have no metal to touch into the Integrated circuit. Was powered using 35 plus 35 volts supply, 3300uf each rail for condensers, speakers impedance 8 ohms. Since the first moment i had full positive rail voltage into the "B" channel...the other channel operated normally but the temperature was too much big.... sometimes reached 80 degrées celsius into the plastic cover..the black cover (gray)... i suppose heatsink had a bigger temperature, was not measured... thermal protection have not entered into operation. Them i decide to reduce voltage, and the unit goes operating using 17.5 volts plus 17.5 volts (datasheet said more than 10 plus 10 volts)... operated warm and sound was great...much better than 35 plus 35 volts. Well...the rigth channel damage was creating problems, i could not switch off positive and negative supply from the rigth channel to let the unit work in peace. Finally, what was obvious happens, the integrated circuit started to have off set floatings.... sometimes speaker jumped forward and then jumped backwards... fuse was 5 amperes and the unit was sending less than that... my speakers (2 units, 4 ohms each, 150 watts each) can hold the DC power on them without problems if less than 30 seconds. I have made a video showing you what happened..... the chip is dead...buried and will not produce problems to me anymore.... there's another youtube video into "Dx Amplifier" that shows the unit operating yesterday...of course..when already alive. Visit youtube to understand what happened: http://www.youtube.com/watch?v=PtlR7qGu3xk regards, Carlos
A good movie to Dx builders...by appointment: http://www.youtube.com/watch?v=cl_A9gKbslk&hd=1 |
#2 |
The heatsink was between the transformer and the chip board.... the integrated circuit was insulated...no electrical contact with the heatsink or other chassis part. regards, Carlos
#3 |
Are there fake units alike this one? (LM4780) regards, Carlos
#4 |
#5 |
Dislike the over current and over voltage protection...produces noises. Here you have one video about this chip... there are others, type Dx Amplifier and others will appear, also this chip playing music. http://www.youtube.com/watch?v=pLNCR2X57bw regards, Carlos
#6 |
The second one burned with i was fliping a switch. http://www.youtube.com/watch?v=F5tr4gHsNkU regards, Carlos
#8 |
...what they mean.... but seems may be something good. Thanks regards, Carlos
#9 |
Great stuff!
I approve of your taste in tunes - Stevie Ray's Tin Pan Alley on your sonic voyage |
#10 |
Be happy into beautifull Canadá regards, Carlos
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 12:37 PM |
| Lm4780 | wotsascott | Chip Amps | 28 | 14th January 2007 08:59 PM |
| Everything Ok in my LM4780 amp? | zenocosini | Chip Amps | 0 | 8th November 2005 11:13 AM |
| Page generated in 0.10126 seconds (84.43% PHP - 15.57% MySQL) with 11 queries |
