| Chip Amps Amplifiers based on integrated circuits |
This is a PCB i got from a junk shop, contains all components like rectifier, filter and mostly all components needed for a power amplifier except the IC. looking closely this is wired in bridge mode (BTL) the IC has 14 pins
Pins description: Pins 1,8,10,13 ground. 7 +Vcc. 3 inv i/p 2 non inv i/p (the input signal is given here. 4 & 11 output (BTL) will post full details if needed and in true DIY spirits i decided to make a powered speaker for my ipod, and i did search the web (Google) with no results regarding the IC used.Any help in identifying the IC will be appreciated thanks in adv
SivanandBalan |
#2 |
no responce ( ??????????)
i think i will have to post pics and more details
SivanandBalan |
#3 |
I like to enter my guess in the lottery. . . a somewhat under-volted stereo automotive chip amplifier from ST Thompson?
Anyway, a magnifying glass and a flashlight could possibly let you read the details right from the chip itself. ![]() EDIT: Next guess would be a slightly big op amp, such as used to power computer speakers. Although, if you were really, really lucky, its something from MPS, but I think nobody is lucky enough to find a bridged MPS MP7720 or something like that. |
#4 |
The chips were missing from the pcb and the supply volts is 12V.most probably the IC is LA series from Sanyo as am told.
SivanandBalan |
#5 |
Some pics...
SivanandBalan |
#6 |
SivanandBalan |
#7 |
that these boards are made for LA4705N-08N family please check existing schematics allover the net
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#8 |
No....the pin numbers r different..Thanx anyway for the reply !!!
SivanandBalan |
#9 |
Finally..i got the answer from WWW wide goose chase...
its LA3508 dual ch amp. the circuit is in BTL mode..
SivanandBalan |
| Page generated in 0.07304 seconds (86.32% PHP - 13.68% MySQL) with 10 queries |
