Lm3886 Bridged Problem
Old 6th September 2008, 10:56 PM   #1
kanifee is offline kanifee  United Kingdom
Default Lm3886 Bridged Problem
Hoping someone can help, today i made up an lm3886 bridged amp, well atleast one channel for now on some matrix board, ive constructed the psu and tested voltages rigged up the amp and its powering on fine no shorts or anything nasty. i hooked up an old speaker to it with my pc as the source and it has a deep low noise hum, the music is also very very very low, its so low you need to move your head to the speaker to ensure its playing. have you guys got any idea?
Old 7th September 2008, 05:45 AM   #2
zei is offline zei  Sweden
Hi
What schematic did you use?
Can you provide some pictures.
Thanx
/JZ
Tala r tiga, silver r guld
Old 7th September 2008, 08:52 AM   #3
It was nationals schimatic, the only change i had to make was for the 51.1k resistor i had to use 3 in series to atain the value i needed this was the same for the 51.1k ohm.
Like i say there is faint music so its sort of working lol!
this is board, i doubt youll be able to make anything out i struggle and i made it! everything is wired correctly, ive checked double checked and triple checked
Old 7th September 2008, 09:20 AM   #4
sangram is offline sangram  India
How are your grounds routed?
In a bridged amplifier the load is floating, but each amplifier needs to 'talk' to the other's ground to minimise errors. It sounds to me like the two grounds are not connected correctly.
When I run amps bridged, I use one signal ground, one power ground and tie up both amps to the return points. If you have a star ground for each amp and connect the two together, noise will appear on the inputs as a function of power supply loading. Theoretically this should cancel out as the load currents in each amp are the opposite of the other. Theoretically.
Most readymade PCBs are optimised for stereo, but since you have a vero you can configure it freely. I do have a bit of this problem on my readymade PCB (Peter's 4780 kit) where the source is a balanced amp. The grounding is a nightmare to reroute, but I got it to work with minimal hum.
Edit: I usually check both halves of the amp when running them in bridged mode. Connecting a speaker between the output and power supply ground will reveal the status of the amplifier. And other mistakes are usually grounding errors.
Old 7th September 2008, 09:46 AM   #5
jackinnj is offline jackinnj  United States
jackinnj's Avatar
do you have the mute properly working -- that's the first thing to check.
check the value of the resistors you "series-ed" to come up with
51K -- the bridged amps really need the resistor values matched such that the gains of both halves are equal. There is a slight mismatch with the values shown. (I use 46.4k/4.75k and 51.1k/4.75k)
you also have to make sure that the heat sink is properly sized for bridged amplification -- you can use the calculator on National's website. if the heat sink is too small, load too low or supply voltage too high the thermal protection will kick in.
while you should be able to get the amp to work with Vero-Board the reality is that you have a comparatively high gain power circuit which is very susceptible to oscillation, particularly with leads dangling all over the place. Peter Daniel does a beautiful job of point-to-point wiring with some of his amps and I would look to his website for how it is done. With long, dangling leads the chipamp will pick up RFI, EMI unless you bypass the power pins as suggested by Nat Semi.
Just as a matter of precaution I would suggest that on each output leg you place a zobel consisting of 2.7R in series with 100n.
Old 7th September 2008, 09:56 AM   #6
this is fromt he top side, i done as you asked and used the ground on the psu as the referance for each chips output, i get audio at a very very low level with no hum from the right (circled in black) but i get nothing but hum from the left (circled in red) the red lines are the earth track i have made from the input.
I also think i should mention im using pin 1 and 5 of the lm3886 for v+ input, wasnt sure if it was just one or the other i should be using so i used both!
Old 7th September 2008, 12:39 PM   #7
pacificblue is offline pacificblue  Germany
The right is the inverting or the non-inverting IC?
And yes, you should connect 1 and 5. It doesn't look as if you did in your photos though.
Old 7th September 2008, 12:58 PM   #8
power lead isnt connected int hat photo but it is at the moment, right is the inverted, have gone back and looked over the data sheet, i have left the muts pin open so mute is on yes? how do i figure on the resistor i need to open the mute pin and what do i connect it to? is it v-?
Old 7th September 2008, 01:53 PM   #9
jackinnj's Avatar
The mute pin is to be connected to Vee via a resistor such that current flows FROM the pin to the neg supply. I have used 8.2K + 10k, 22K etc.
the mute takes 0.5 mA to turn the device on.
Old 7th September 2008, 01:57 PM   #10
terminology has lost me a little, vee? is that signal in or voltage+ in?
Lm3886 Bridged ProblemHide this!Advertise here!
My Bridged LM3886 robertj88 Chip Amps 12 31st October 2010 03:47 PM
Bridged LM3886 psu. kanifee Chip Amps 18 4th September 2008 01:57 PM
Bridged LM3886 (again ?) Puffin Chip Amps 24 14th February 2008 08:10 AM
Looking for a PCB for bridged LM3886 zafira1981 Chip Amps 1 29th March 2006 03:39 AM
LM3886 Bridged Amp soundNERD Chip Amps 1 20th January 2006 01:36 PM
