Old 4th September 2008, 09:34 AM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Question TPA6120 as a preamp..
Hi all,
I wonder if a TPA6120 can be used as a preamp module for a gainclone or etc. amp?
Its a current feedback amp and has very low THD at high iimpedance loads (like 10K). With this way, we can have a very cheap and high quality preamp with a headphone output (splitted with a relay). Of course with a 2 or 3X gain stage (with OPA2134 or LM4562) and an attenuator just before TPA...
Any comment or advice?
Best regards,
Ozgur
Old 4th September 2008, 11:58 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
The answer is yes but 12 uA as input current may casue you some trouble. Despite that it is wonderful. I have used it in my headphone amplifier.
/Per-Anders (my first name) or P-A as my friends call me
Old 4th September 2008, 12:03 PM   #3
Dxvideo's Avatar
Right,
But I will use a buffer stage (may be with 2x gain) before it like yours. You use TPA as inverted and your buffer stage is non inverted and the total phase response will be as inverted.. Is there any speacial reason for this? Because I plan to use all non inverted..
Best regards,
Ozgur
Old 4th September 2008, 12:09 PM   #4
peranders's Avatar
It's no problem if you want to have a non-inverting amp.I used inverting mode because the distortion will be 10 times lower (in theory). Since I already wanted to eliminate the 12 uA problem I could also use inverting mode with 1 kohms input impedance. The TPA6120 demands rather low ohmish resistor values in the feedback.
Old 4th September 2008, 12:13 PM   #5
Dxvideo's Avatar
Ten times is a good ratio! I think its worth to try..
But I am planning to put a potentiometer before TPA.. And the TPA will work as DC coupled like yours. In this case it will be problematic..
Do you have any advice about that?
Best regards,
Ozgur
FS: Headphone amp PCB TPA6120+OPA2134 mravlcax Swap Meet 0 25th January 2009 02:43 PM
TPA6120 Question Dxvideo Chip Amps 6 4th March 2008 08:14 AM
TPA6120 headphone amp with servo nelsonvandal Headphone Systems 3 8th November 2007 07:54 PM
parallel TPA6120? bob_v5 Chip Amps 31 30th October 2007 09:36 AM
Page generated in 0.07261 seconds (72.15% PHP - 27.85% MySQL) with 10 queries
