| Chip Amps Amplifiers based on integrated circuits |
So...
I'm trying to figure out how to power my monster 7.1 gainclone beast. I haven't mapped out the power (watts) per channel part out, but i was wondering.. Will a single retifier work for all 8 channels? Reason I ask is i'm trying to convert my 2 channel amp to multiple channels, and i'm not entirely sure if i should use a retifier for every 2 channels. might sound dumb, but i'm curious. Regards, dan |
#2 |
You want to know, if there is a rectifier big enough for a power handling that you haven't defined yet?
Well - don't worry. There are recifiers big enough for any amplifier that you can design. Look here for an example. That thing is good for 2000A at 250kV.
#3 |
you can run multiple channels inside one amplifier chassis. I wouldn't. I like the amps beside the speakers, with very short speaker cables resulting in long interconnects at line level. Do you have a single rectifier fed by a centre tapped transformer or dual rectifiers fed from dual secondaries?
regards Andrew T. |
#4 |
MY input:
http://www.new.facebook.com/album.ph...1&id=607902362 This is going to be used for movies? Depending on your standard listening volume one 500VA transformer should be good. 600VA should be more than good enough. Build a decent dual bridge rectifier circuit with a decent 2 winding toroidal. Read through this web page: http://www.tnt-audio.com/clinica/ssps1_e.html |
#5 |
for my 8-chennel amplifier basedon lm4780, i am using a 800 va transformer with dual rectifier units (one for each channel).
And the system is running fine in terms of normal heating of rectifier diodes and transformer.
. . .. ... ..... ........ ............. ..................... .................................. My Best LM3886 PCB layout |
| Multiple subwoofer/multiple amp question | boogs | Subwoofers | 5 | 13th November 2007 04:36 AM |
| question about multiple input transformer in same tube mic pre. | limey222 | Tubes / Valves | 0 | 12th January 2007 12:15 AM |
| First Gainclone. AX-730 Transformer Question. | bezel6 | Chip Amps | 14 | 22nd January 2006 10:08 PM |
| multiple 6x9 speakers at one channel | tobler | Car Audio | 3 | 24th November 2005 07:35 PM |
| Multiple primary power transformer question | trombone | Tubes / Valves | 7 | 23rd May 2005 04:36 PM |
| Page generated in 0.07986 seconds (73.58% PHP - 26.42% MySQL) with 10 queries |
