Worlds smallest amp?
Old 23rd August 2008, 04:30 PM   #1
Rikard Nilsson is offline Rikard Nilsson  Sweden
Default Worlds smallest amp?
Now when my two monoblocks are in the workshop being converted into HEC high performance units (hopefully) I have no sound at home! Terrible! So, I decided to solve this as quickly as possible. At least I have to be able to watch TV with sound.
Result: 2 bridge mode IC amps and a switching power supply.
Sounds good right? Mohohaohaaaaaa......
Well, the supply is an old cell phone charger...and the amps are TDA7052īs putting out a staggering 2 x 1 watts......
Old 23rd August 2008, 05:27 PM   #2
barry.childs is offline barry.childs  United Kingdom
barry.childs's Avatar
I think there is room for a Votexion Tape Recorder between the two amps!!!
Old 23rd August 2008, 05:44 PM   #3
gni is offline gni  United States
gni's Avatar
Classic DIY. . . reuse them parts!
Old 23rd August 2008, 07:55 PM   #4
EmergencyDpt is offline EmergencyDpt  United States
EmergencyDpt's Avatar
Send a message via Yahoo to EmergencyDpt
Small enough to smuggle inside a body cavity! Excellent work.
Don't eat mud, if you can help it.
www.EmergencyDpt.com
Old 31st August 2008, 09:20 AM   #5
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
That inspired me to shrink a TDA7294.
Old 31st August 2008, 10:00 AM   #6
lineup is offline lineup  Sweden
lineup's Avatar
can i be done much smaller
yes, of course
SMD Version of some common dual op-amp = left and right channel
+ SMD resistors and two eventual SMD output buffer transistors
Such transistors can come in e.g. D2-PAK
which can take a few watts, even without heatsink.
What sabotage it all are those GIGANTIC RCA Phono
The ouput connector may be hardwire
because normal loudspeaker terminals
would look like World Trade Center beside a normal house.
More reading:
Surface-mount_technology#Package_sizes
http://en.wikipedia.org/wiki/Surface...#Package_sizes
Lineup
Lineup Audio Members Blogs
Lineup Audio Community Projects
lineup
Old 31st August 2008, 11:00 AM   #7
This made me remember a very small construction from the days I worked as a TV repair technician. There was a Sharp set about 10 years ago that used a OP based class D amp with SMD output transistors! Provided about 10 watts, but with terrible distorsion figures.
But it could be a way of building an extremely small amp with decent power!
I was the Sharp 70CS03 bt the way. LF output stage attached.
Old 31st August 2008, 07:09 PM   #8
lineup's Avatar
okaey
your amplifier is the smallest so far, Rickard
Congrat
But you wait some days/weeks .....
I'll be back with MY pictures
of some thing even smaller
lineup
Old 31st August 2008, 11:42 PM   #9
Now if you want to talk small, ask my wife!!! or you can make a crystal set small enough to fit on a thumb nail (less earpiece), and if you think it is cheating because of the earpiece you can listen very carfully to the crystal, and all you need is a crystal diode and a tiny bit of coiled wire. But give the dude credit, it is small; damned phono sockets; They spoil everything small. Cheers Barry
Old 1st September 2008, 12:23 AM   #10
wakibaki is offline wakibaki  United Kingdom
Banned
I been tryin' to work up the nerve to try to solder these Max9703s
I tinned one board, but it looks ugly ugly.
w
Worlds smallest amp?Hide this!Advertise here!
Worlds smallest HiFi valve amp fergs1 Tubes / Valves 51 17th September 2008 12:32 PM
FS: Worlds smallest Sonic Impact mod theAnonymous1 Swap Meet 0 20th May 2006 09:06 AM
The best of both worlds? annex666 Tubes / Valves 13 16th February 2005 09:58 PM
The best of both worlds? annex666 Solid State 8 31st August 2002 10:28 AM
Copyright ©1999-2017 diyAudio
