| Chip Amps Amplifiers based on integrated circuits |
#671 |
that looks like a gauss band around the transformer winding. An indication that they have spent a bit of money on trying to improve the performance standard of the transformer.
Are those the mains connections exposed on the bottom side? In their present exposed condition they could be accidentally shorted to each other or to core. Take care.
regards Andrew T. |
#672 |
AndrewT: Yes, both the primary and secondary connections are exposed, they were mounted facing the bottom of the amp. I am thinking of mounting it upside down so that the connections are easilly accessible. I will most likely put it upside down so that the connecions are easy to access.
#673 | |
Or we may be talking about different aspects of comfort. E.g. you may be uncomfortable with so little power, while I am comfortable, because the supply voltage leaves safety margins in the IC's voltage rating and heatsinking.
What I fail to see is, how those snubbers should bring the noise floor in the audio band significantly down. The caps in that "Snubberised PSU" are so small, they only work far above the audio band, if at all. And resistors don't remove noise, but add their own. What makes it worse is that those snubbers are in the wrong place to do any good. You want to bring power supply noise down? Add 10-100 nF capacitors next to the rectifiers to fight diode switching noise. Then add big smoothing caps to filter the AC components out, and that is where you really determine the power supply noise floor. Finally you need 10-100 nF decoupling caps next to the supply pins of all ICs and that's it. You may still need a mains filter to achieve your ambitious goal, but the noise that comes in from mains does not really count as the power supply's own noise and will certainly not be impressed by snubbers.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#674 | ||||
Building to that quality thresh hold = more, better. Quote:
Your results may vary, but I have come very close to (IMHOP) the ideal -110db PS noise floor = which compliments the 105-120db dynamic range of 24bit-48k/96k/192k of DVD audio track (and pro music recording studio quality). --- "All of the world's problems can be fixed by resolving the impedance mis-matches ..." - Bob Porter / Mad Science
Over compression is a problem with modern CD recordings Last edited by FastEddy; 7th October 2011 at 05:55 PM. |
#675 |
Hello friends!!
I have no more idea about it.But I think you can more help about by google search. |
#676 |
The link in post #1 is invalid. Is there a new link Nuuk?
#677 |
#678 |
Thanks John!
#679 | |
Over compression is a problem with modern CD recordings |
#680 |
I haven't read through the document fully yet, and I won't be constructing my own PSU, but one quick question before I start wiring up my chip-amp. This is very basic and easy... Is it common practice to tie the PSU ground to earth ground at some point, or does it float internally? What about all the connectors that fit to a metal enclosure?
| A Beginners Guide to Enclosure Alterations | Bork | Multi-Way | 7 | 12th January 2009 02:10 AM |
| beginners ecl82 power supply | emil_86 | Tubes / Valves | 15 | 25th September 2004 05:20 AM |
| Page generated in 0.10127 seconds (68.88% PHP - 31.12% MySQL) with 11 queries |
