Chip amp power supply- a beginners guide - Page 57 - diyAudio
Old 30th August 2010, 10:53 AM   #561
Hi. Yet another noob Gainclone DIYer here. Has anyone seen this power amp PSU circuit Power Supply for Power Amplifiers ? Seems to happily use two bridges from a centre tapped transformer.
Old 30th August 2010, 12:06 PM   #562
it is not a dual bridge from a dual secondary.
It is a single bridge from a CT secondary in parallel with an identical single bridge from the same CT secondary. If you power two amplifiers from this you may find problems eliminating hum. I'm not sure you can eliminate the hum. I couldn't.
Someone show me how.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th August 2010, 01:58 PM   #563
What's the expected source of hum? As the author sells this PSU as a kit you'd think, if there was a problem, someone might have complained? The site is worth exploring - many good articles and circuits.
I was planning to use this as my PSU circuit, with some pi-filtering resistor ideas and a regulator circuit from Roman Black Roman Black's gainclone amp .
This is my schematic so far (I'm incautiously confident I won't have to retitle it 'instant pyrotechnic device' but not so sure, now, about having to call it 'very expensive 50Hz tone generator'): Click the image to open in full size.
Old 31st August 2010, 09:46 AM   #564
tangmonster's Avatar
That 35-0-35 ac transformer is going to give you nearly 50V dc
What load speakers are you going to use? a 20V drop over your regulator is going to dissipate too much heat.
Here is a simpler regulated powersupply design:
PA100 DIY 2x LM3886 in parallel gainclone audio amplifier
You need +-28V dc for 4 Ohm loads. for maximum power into 8 ohms you need +-35Vdc
Old 31st August 2010, 10:52 AM   #565
Forget the regulators and buy the correct transformer.
Or
keep the transformer and build an amp that suits +-50Vdc.
regards Andrew T.
Old 31st August 2010, 11:19 AM   #566
Thanks for the feedback and suggestions.
8ohm speakers.
I just found a 30-0-30V 160VA toroid (ah, the happy glow of finding a vital, expensive part bought 10 years ago and forgotten about, hiding the the back of a cupboard - YES!) so I can dispense with the dual rectifier centre tapped design from Elliott Sound Products and go with a full twin secondary design. I already have have the LM317s and PNPs for the regulators and the LM317's control resistors in the circuit shown are already set up to provide 35V... so I may as well build it.
Old 27th November 2010, 08:30 PM   #567
sardonx is offline sardonx  Canada
Well one more person needing help here I got some bridged tda7293 boards off ebay that call for a power requirement of 30 to 35 volts Dc. TDA7293 parallel BTL mono power Amplifier borad 350W - eBay (item 120595963571 end time Dec-11-10 06:58:28 PST)
I have a dual secondary 2x20 volts ac 400VA plitron trafo. The picture shows how it's wired. When measuring the assembled supply with no load, from v+ to v- i'm getting a reading of 48 volts. But measuring from ground to v+ i'm getting around 30. This makes sense to me but the 48 volts does not... I'm wondering if i did something wrong or i fried the boards cuz when i had it hooked up and turned it on there was a buzzing sound and then complete silence. No smoke, no heat on the chips nothing.. did i do something wrong?
The End
Old 27th November 2010, 08:49 PM   #568
some help on TDA7293 boards off Ebay
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 28th November 2010, 10:35 AM   #569
post567
what is the 5th (middle) ground wire going to?
It is not needed for a dual secondary transformer, it has no centre tap.
Could it be going to the Safety Earth?
regards Andrew T.
Old 30th November 2010, 05:28 PM   #570
FastEddy's Avatar
post567
One might also consider paralleling the dual secondaries transformer for just 20 VAC out put = 28.5 volts DC after connection to a single diode bridge ... OR ... connecting the dual secondary transformer outputs and passing that through a single diode bridge = giving one a true center tap between the series coils (as is "standard" practice).
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 03:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 06:20 AM
Copyright ©1999-2017 diyAudio
