Old 10th January 2010, 11:31 AM   #531
Tripmaster's Avatar
Richard
My photostream: http://www.flickr.com/photos/59839778@N04/
Old 1st February 2010, 07:52 PM   #532
Tripmaster's Avatar
Originally Posted by audio1st View Post
If it is OK you can unscrew and remove the 1u5F cap, cut the wires near the board and remove the 100k resistor near the input.
Hi Barry
The amp is working OK, and hasn't blown a fuse. I haven't removed these parts, do they need to be removed?
Richard
Old 3rd February 2010, 04:02 PM   #533
audio1st's Avatar
Hi Richard
Not necessarily..
Barry
Old 14th February 2010, 12:31 PM   #534
dodo is offline dodo  Poland
Hi I have question to some EE
How importnat is the transistor matching in the cap multiplier circuit , f.e. in Pedja discrete regulator
Old 14th February 2010, 07:03 PM   #535
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
To be honest Dodo - I don't know! I have only ever bought those transistors in ones and twos so have never had the chance to match them.
However, I've built four of those modules now and they all appear to work very well without any problems!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 15th February 2010, 09:40 AM   #536
Tripmaster's Avatar
Hi Dodo
I built a pair of these last year, and from what I can remember the transistors don't need to be matched. I think its preferable to purchase them with a '-16' e.g BD139-16 as it of guarantees a certain power output within a range.
Transistors sold without the -16 extension could have a wider tolerance.
I maybe wrong, but I'm sure someone will correct me if I am.
I hope this helps
Richard
Old 15th February 2010, 11:34 AM   #537
no need to match or select, just solder them in.
The 16 indicates the gain range (hFE at the specified test current and temperature).
regards Andrew T.
Old 15th February 2010, 12:04 PM   #538
Tripmaster's Avatar
See...it didn't take long
Richard
Old 5th April 2010, 03:24 AM   #539
electra_ina's Avatar
This is my GC LM 3886 with PSU. Dioda I used RHRP3060 dan 4 transformer 0-24VAC..
Dioda:
Old 20th April 2010, 04:39 AM   #540
FastEddy's Avatar
Originally Posted by Tripmaster View Post
Hi Dodo ... I built a pair of these last year, and from what I can remember the transistors don't need to be matched. ... I hope this helps
Tripmaster is right on here! (So is AndrewT.)
Trying to "match" the power supply regulation transistors is like chasing that last 1% in engineering design. Too much work for too little reward.
Better point: How about dual "pilot light" LEDs instead of the single LED1 = This would do a better job of more closely "balancing" or "matching" the +/- rail voltages.
If you really want to make the two +/- rails "match", you might consider a variable pot substitute at R13 (= 2k linear variable trim pot) ... which would let you more closely match the minus (-) side rail with the plus (+) side ... find a really good volt meter for this. Best to "trim" under load = amp(s) all running and connected to speakers, input source quiet but connected. When you get to a 3 decimal point match, seal it and ignore it for at least 1 year, then trim it again ... I would bet no future trimming is necessary.
(Don't try matching the Zener Diodes ... )
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 03:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 06:20 AM
Page generated in 0.11035 seconds (76.09% PHP - 23.91% MySQL) with 11 queries
