| Chip Amps Amplifiers based on integrated circuits |
#501 | |
I'm not sure its fair to give the name of the vendor as they maybe unaware of this. I wouldn't want it to affect the sales of their other products. The vendors been quite helpful so far. The manufacture is LITE Audio Regards Last edited by Tripmaster; 28th December 2009 at 07:57 PM. |
#502 | |
#503 | |
Theory in the form of Kirchhoff's Current Law predicts a power consumption of > 18 W. audio1st measured a consumption of 20 VA in practice. The relay consumes only 0,9 W, which leaves most of the power to be dissipated. The 1µ5 capacitor is the only device, where that can happen due to its function in the circuit (voltage divider) and due to its physical size.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#504 |
Quoted from the article:
Direct rectification normally gives a voltage approaching the peak value of the mains voltage, but placing an impedance in series with the ac input reduces the dc output voltage. If the impedance is resistive, low efficiency results. However, if the impedance is reactive, the circuit is essentially lossless, except for diode losses and a small power loss in the parasitic series resistance. I don't know how much more plain it could be... |
#505 | |
Barry. |
#506 | |
"Essentially lossless" is not a plain explanation. It is a statement that becomes absurd, when you read later on in the text
audio1st measured a consumption of 20 VA to activate a 0,9 W relay coil. The difference must go somewhere. That is plain to me.
#507 | |
David
#508 |
Tested with 160 ohm load, figures are, 20VA, 2W and .08 power factor.
DC voltage across load now 15V, was 5V with 47ohm load. The resistor I thought was parallel to the coil is only connected before the relay is powered, I guess 150ohms, this keeps the load and voltage constant. Barry. |
#509 |
So, in laymans terms are these soft start modules any good?
#510 |
most mains loads are inductive and that lowers the power/load factor. If we take current through a series connected capacitor to our circuit (soft start control), do we raise the power/load factor of our total household demand? |
| A Beginners Guide to Enclosure Alterations | Bork | Multi-Way | 7 | 12th January 2009 02:10 AM |
| beginners ecl82 power supply | emil_86 | Tubes / Valves | 15 | 25th September 2004 05:20 AM |
