| Chip Amps Amplifiers based on integrated circuits |
#481 |
soft start and no transformer and the bulb glows dimly?
regards Andrew T. |
#482 |
yes
#483 |
I purchased two soft-starts modules, and I have just wired up the second and it also dimly lights the bulb
#484 |
If it happened on both primaries at the same time, but not on the secondaries, something must have happened on the primaries. I blew the fuses once on a commercial amp, when I involuntarily switched it on-off-on very fast. The soft-start circuit had not yet bridged the resistors, yet still I had obviously managed to switch the mains on for the second time just when the transformer core was magnetized the wrong way round for the incoming mains. Maybe you have experienced something similar due to contact bouncing from your mains switch.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#485 | |
I don't have any fuses on the transformer secondaries, only the primary winding. What's puzzling me is that both soft-start circuits make the bulb glow. Is a bulb tester compatible with a soft-start module? I recently repaired an LCD monitor, when I attached the bulb to the SMPS it made the bulb flash as it was trying to charge. The power supply was OK. What is your name by the way? Happy Christmas! |
#486 |
When you load a transformer, the secondary voltage drops. There can be situations, where the secondary load leads to a balance of voltage and current that does not trip the primary fuses although the secondary current is overloading the transformer. That is, why transformers should always have secondary fuses at or below the transformer's nominal rating.
The light bulb is not a very precise indicator. It is hard to assess how dim or bright it is from a photo. The brightness depends on the bulb wattage, the load and their interaction, and your perception of dim and bright may be different from mine. So it is hard to tell, whether it is okay that the bulb lights up with only the soft-start module connected. although it seems a soft-start module should not be drawing a lot of current on its own. You could try a bigger bulb than 40 W. If you want to be really sure, you need to measure the current that actually flows and compare it to the device's specifications. Since that involves work on the mains voltage, you should only do it, if you really cannot avoid it and work with utmost care. Use a jumper across the meter, when you switch the power on, and remove it after the inrush current has passed. And be careful not to touch anything live, while testing. The DUT should be connected to a ground fault circuit-breaker and you should keep one hand in your pocket, while working. Happy Christmas to you, too. David
#487 |
Tested without soft-start circuit
Hi I have tested the transformers and power supplies with the bulb tester, then each amp. The bulb glows momentary and then goes out completely with the transformers and PS. The same happens when I connect the first amp. When I connect the second amp the bulb filament barely glows...I have to get up close the see if it is lit or not. I guess everything is OK. I will buy some secondary T1-1.6A fuses tomorrow as these need to be fitted. Do you think is worth fitting a slightly higher rated fuse on the primary/mains inlet? So the issue with the soft-start circuit still remains. Is it faulty? I'll email the supplier to see if they can offer some advice and I will report back. Thanks again for your help. |
#488 |
The transformer must be protected against two things.
One is overload, which you do on the secondaries with slow-blow fuses rated smaller than or equal to the nominal secondary current. E. g. on a 300 VA transformer with 25-0-25 V you need 300/2/25 = 6 A or smaller fuses. You can use smaller fuses, if the transformer is oversized. The other is short-circuit. Short-circuit protection must be installed before the primaries and the slow-blow fuses there should be rated as small as possible, but big enough to avoid nuisance blowing. Since a short-circuit means significant current draw, the primary fuses can be bigger than the nominal primary current, as they will be tripped anyhow. A rating of twice or even three times the nominal current is not unusual. They should however be smaller than the next fuse before them in the circuit and they should be small enough to ensure cable/wire protection according to your local regulations. Or the other way round: once the fuse size is determined, you need to choose the wire diameter big enough to cope with the fuse rating. The primary fuses should also be big enough not to trip before the secondaries except in the case of a short-circuit in the primary windings or mains wiring. If the soft-start module draws more current than the amplifier, it is either faulty or extremely bad designed. What strikes me as odd in the photo in post #476 is that a 12 V relay is fitted, when the power supply is 240 V, but no transformer seems to be present. That would mean that 228 V times the relay coil current must be dissipated as heat somewhere, probably something like 17 W or so, yet there does not seem to be any component apt to do that on the PCB. Regards David
#489 |
Hi David
I am a bit confused regarding the secondary fuses. Andrew quotes much smaller fast blow fuses in the following link Chip amp power supply- a beginners guide Are you suggesting the fuses be placed before the smoothing capacitors? Here are some close-up photos of the soft-start The three transistors on the board are 2N5401 Thanks
#490 |
that capacitor is rated 1u5F @ 400Vac and captioned on the pcb @ 630Vdc.
It appears the soft start is using mains voltage and dropping the excess voltage using the capacitor to leak working current through the high impedance of the capacitor. It will pass ~ 100mAac from 240Vac 50Hz. It's not a nice way to do it, but when competantly designed it does work. Be careful the soft start is working at mains voltage!!!!
regards Andrew T. |
| A Beginners Guide to Enclosure Alterations | Bork | Multi-Way | 7 | 12th January 2009 02:10 AM |
| beginners ecl82 power supply | emil_86 | Tubes / Valves | 15 | 25th September 2004 05:20 AM |
| Page generated in 0.10741 seconds (71.63% PHP - 28.37% MySQL) with 11 queries |
