Chip amp power supply- a beginners guide - Page 48 - diyAudio
Old 13th December 2009, 02:58 AM   #471
lanchile's Avatar
Originally Posted by Tripmaster View Post
Hello
I have a soft-start circuit, and I am using a T1.6 fuse in the mains inlet, and a 3A fuse in the mains plug as per Andrew's recommendation. I just wanted to know if I needed to untwist the two primary Lives and Neutrals and insert a 800mA fuse per each transformer Live wire, rather than leaving the two neutral and live wires (two transformers connected together) connected and fusing each twisted pair with a 800mA fuse.
I hope that makes sense
Thanks again
if you already have fuses T1.6 (neutral/hot)before the soft start.I would leave those twisted wire alone.try to twist the ac wires as much as you can.
Old 13th December 2009, 08:05 PM   #472
tvrgeek is offline tvrgeek  United States
Any recommendations for high speed diodes to replace the usual 1N4xxx series? Shottcky or "fast"? I am not sure I believe the hype that they can make a difference in the sound of an op-amp based circuit providing proper cap size and location, but worth a try.
Old 18th December 2009, 07:15 AM   #473
Tripmaster's Avatar
Hi there
I have just added a winding to one of my 300VA transformers. The new winding outputs 7 VAC. As you can see I have crudely soldered a 400R resistor to the LED anode pin and have soldered a diode across both LED legs, the diode anode leg is soldered to the LED anode.
I'm guessing it doesn't matter having too much resistance providing the resistor is of a suitable wattage and I am happy with the degree of illumination.
The LED lights up and is not overly bright so I guess everything is OK.
Can you see any potential problems?
Old 18th December 2009, 09:06 AM   #474
have you really wired the LED to diode, anode to anode?
This would limit the LED voltage to ~650mV and the LED would not light up.
The LED would also see the full 10Vpk in reverse direction and probably fail.
If the diode is passing current in one direction and the LED is passing current in the other direction then all the problems go away.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th December 2009, 11:20 AM   #475
audio1st's Avatar
Hi Andrew,
Richard has confused the name of the end of the diode with the line marking. He has actualy conected cathode of diode to anode of LED, this is shown in the pic's.
Old 24th December 2009, 09:53 AM   #476
Tripmaster's Avatar
This has become cringe worthy!
I've been running my dads newly built amp for 12 hours a day over the last week without a problem.
The mains inlet is switched, but is a little awkward to get at so I have been switching the amp on and off via the 6 way gang socket. I switched it on this morning and nothing happened. There was a faint twinkling front the led on the front, but nothing else. I then removed the lid to find that the T1.6A mains inlet and the two T800mA transformer primary fuses had blown.
I've visually checked over the parts in the amp and I cant see any component faults or shorts. I've just replaced the three fuses and powered up the amp using the light bulb tester and the 40w bulb glows like it has always done, dimly. The amp still works OK.
Can I put this down to nuisance fuse blowing or do you think it could be something serious?
Sorry to hog this thread!
Old 24th December 2009, 11:42 AM   #477
All three fuses blown at the same time says something drew excessive current.
Check the 47r resistor is still in spec.
Can you disconnect both amplifiers from their PSUs?
If you can, do the bulb test with just the transformers and the PSUs online.
Then add one amplifier. bulb test, then the other amp, bulb test, then both amps, bulb test.
What is the bypass relay time delay? I wonder if you could series connect a pair of 47r Power resistors to slow down that initial start up?
regards Andrew T.
Old 24th December 2009, 12:09 PM   #478
Tripmaster's Avatar
The 47R power resistor is still in spec and the relay clicks at about 2 seconds.
I can disconnect the amps and PSUs, they are soldered so the solder pads may or may not withstand another two heatings. Should the bulb filament remain off until I connect the faulty amp/psu?
Old 24th December 2009, 12:31 PM   #479
the bulb should be completely off when only the transformers and the PSUs are coupled.
The bulb may glow very dimly with one good amp connected. Check to see that both are OK.
Soldered joints. Pity that. Consider cutting the wires and inserting a terminal block at least until all the checks have been done.
regards Andrew T.
Old 24th December 2009, 01:22 PM   #480
Tripmaster's Avatar
I disconnected both amps and tested the PSUs together, and individually and it lit the bulb every time. I've just tested the soft start circuit and it also lights the bulb, so does this mean there is a fault with soft start circuit?
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 02:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 05:20 AM
Copyright ©1999-2017 diyAudio
