| Chip Amps Amplifiers based on integrated circuits |
#461 | |
#462 |
My experience using the same soft start modules as Tripmaster is that if there is any problem with the wiring from the transformer or on the chip, the SS module will not allow you to turn the amp on.
#463 | |
I'm just getting around to fitting these fuses. I have read the secondary fuses can go after the rectifiers, but its not all that easy with chipamp boards. Will there be any benefit fitting the fuses within the red circle 'primary' side of these transformers? ![]() p.s I'll send you a PM with regards to the LSK170s shortly ![]() Thanks |
#464 | |
Useful fuse rating in the secondary can only be fitted after the smoothing capacitors. Aim for fuse rating ~50% of maximum peak or rms output current into a resistor load = nominal speaker impedance. i.e. 60W into 8ohm is equivalent to 22Vpk and 2.7Apk into 8r0. This requires F1A to F1.6A in both supply lines. 60W into 4ohm requires larger value fuses. The primary fuses are as stated earlier. One T fuse feeding one transformer. Two transformers requires two fuses.
regards Andrew T. Last edited by AndrewT; 4th December 2009 at 01:33 PM. |
#465 | |
#466 |
Me again!
As you can see I have wound the Live wires together from each transformer and have done the same for the Neutral wires. Should I separate the Live wires and insert a fuse for each primary Live, or can I leave them joined together and insert a fuse on the Live and another on the Neutral? As seen below... I am guessing I will need to separate the two Live wires and fuse independently I'm sorry if its becoming a bore! Thanks |
#467 |
#468 | |
Thanks for your help ![]() What I was trying to ascertain was if I needed to untwist the two Live and Neutral wires and fuse interdependently. It does make sense to have access to the fuses externally, but I have a pile of pcb mount fuse holders at the moment. Thanks |
#469 |
If you have secondary fuses that provide overload protection for the transformers, you can use a common fuse for both transformers, because it only needs to protect against shorts on the primaries.
If you have no secondary fuses, the primary fuse has to provide overload and short-circuit protection at the same time. That means, you will need a soft-start circuit to keep the inrush-current low enough for an adequate fuse rating. And you need one primary fuse per transformer.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#470 | |
![]() I have a soft-start circuit, and I am using a T1.6 fuse in the mains inlet, and a 3A fuse in the mains plug as per Andrew's recommendation. I just wanted to know if I needed to untwist the two primary Lives and Neutrals and insert a 800mA fuse per each transformer Live wire, rather than leaving the two neutral and live wires (two transformers connected together) connected and fusing each twisted pair with a 800mA fuse. I hope that makes sense Thanks again |
| A Beginners Guide to Enclosure Alterations | Bork | Multi-Way | 7 | 12th January 2009 03:10 AM |
| beginners ecl82 power supply | emil_86 | Tubes / Valves | 15 | 25th September 2004 06:20 AM |
| Page generated in 0.13573 seconds (88.30% PHP - 11.70% MySQL) with 11 queries |
