Old 11th August 2009, 11:50 AM   #431
Professor's Avatar
Hi all!
Maybe someone need, very interesting scheme of softstart.
http://mymegahobby.jimdo.com/
Old 31st August 2009, 11:45 AM   #432
a complicated soft start circuit.
And part of it is direct mains powered!
Old 1st September 2009, 08:06 AM   #433
Professor's Avatar
No, this part powered if you push the power button SB1 and consumes an electricity at the moment of switching. Only varistors directly connect to mains but you may not use they, and you may not use the interference suppressor.
Old 21st September 2009, 08:19 PM   #434
Skip C1, R4, R5, VD1, VD2 and replace K1 with a latching relay for mains voltage. That is easier to build and much safer.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 22nd September 2009, 01:50 PM   #435
Professor's Avatar
Then the power button with fixing is necessary.
Old 22nd September 2009, 06:29 PM   #436
If you mean with fixing that you need a switch instead of a button, then no. A latching relay toggles between its two states by means of a ratchet mechanism each time the coil is exited. You often find them in building installations, where lights must be switched on and off from many places, e. g. in an aisle, and where this type is used. Other styles are available from many manufacturers.
There are two types of latching relays. For use with a single pushbutton, the single coil type is the right choice. The type with separate coils for setting and resetting requires two pushbuttons.
Old 22nd September 2009, 07:54 PM   #437
Professor's Avatar
Latching relay nice thing but I already used my scheme =)
Old 7th October 2009, 10:41 PM   #438
raypalmer's Avatar
question...
My chipamp.com boards are all done. The PSU measured fine, then I attached the amplifier board. Now it blows fuses. I stuck a 10amp fuse in to see what was happening, the traffo heated up in a few seconds, the inside two diodes on the bridge heated up fantastically hot and the outside two not so much. There was a slight hum coming off the board..... Help... Everything looks to be wired correctly.
Wherever you go there you are.
Old 8th October 2009, 12:10 AM   #439
LucasAdamson's Avatar
Disconnect the amp again to see if the power supply is still as it was?
Check for too much solder causing short circuits across traces on the PCB?
Check the diodes are in the right way around (a common problem I have read).
Old 8th October 2009, 01:16 AM   #440
raypalmer's Avatar
Well I disconnected the V and PG's and the PSU didn't smoke out on me. So that rules out the error being on the psu amirite?
I guess I'll peel off the amp board tomorrow and give it a good eyeballing...
My diodes will be fine right? They got super-crazy hot when I ran it with the 10amp fuse but it seems ok now?
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 02:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 05:20 AM
Copyright ©1999-2013 diyAudio
