Old 12th November 2008, 03:16 PM   #31
pirej is offline pirej  Macedonia
Need help:
I have transformer 32-0-32 ..5 Amperes... and wanted to use to "drive" my Gainclone, made by LM3886 (stereo version).
- If I use 40v capacitors can I get "normal" power supply for GC?(for example 36-37v per rail).
-Is there a schematics for regulated supply in which my transformer will fit? (Lt1083 or somethnig else..) to lower the supply on 35V per rail..
- No way - just to make single supply version (to use as 64V or twice by 32V?)
- Or...
Old 12th November 2008, 08:04 PM   #32
Your transformer puts out 32V AC. Multiply by 1.4 and you get 44.8V DC. The maximum for the LM3886 is 42V. Also, using a 40V capacitor with 44.8V rails will cause destruction of the capacitor. The capacitor is not a limiter, it must be rated for higher than the highest voltage it will see.
A regulated supply is your best bet if you want to use that transformer. Unfortunately I can't help with that.
Old 12th November 2008, 08:18 PM   #33
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Check this thread: LM338 regulated snubberized PSU for audio amplifiers
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 13th November 2008, 07:30 AM   #34
Thnx for the response,
Last question -
The trafo that I have, has only three wires as secondary 32-0-32, which means - NO independent secondaries.
can I use Carlos regulated PSU as shown in attachment?
Old 13th November 2008, 08:42 AM   #35
No.
regards Andrew T.
Old 13th November 2008, 11:51 AM   #36
The last try by me to use the trafo
Is this OK?
Old 13th November 2008, 12:07 PM   #37
Is this OK?
Old 13th November 2008, 12:37 PM   #38
are you trying to get+-24Vdc from your regulators?
Then use a 24Vac or 25Vac transformer.
You need a single bridge rectifier if you use a centre tapped transformer.
You can use either a dual or a single bridge rectifier if you use a dual secondary transformer.
regards Andrew T.
Old 13th November 2008, 02:33 PM   #39
I'm trying to get 35v regulated as max. for stereo LM 3886.
The above schematic is OK with my trafo 32-0-32v?
Old 13th November 2008, 02:51 PM   #40
I would love to build a chip amp based amplifier for my automobile... Any chance of some advise on designing a Power supply for Automobile enviroment ?
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 02:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 05:20 AM
Page generated in 0.08650 seconds (68.85% PHP - 31.15% MySQL) with 11 queries
