Old 6th September 2008, 02:26 PM   #21
! is online now !  United States
Originally posted by Nuuk
Again, I don't want to go into so much detail it looks like a University degree course. However, it is important to stress that a load must be connected to the bridge when taking the measurements. Hence the following quote from the section on testing!
Yes a capacitor must be on the output but that is not a load. A load will consume a significant % of transformer current capacity, while a capacitor only filters, reduces ripple instead of being a load. Without a load you will only see peak output, though it is still a good thing, still important to know the peak voltage because it can't be allowed to exceed the capacitor, chipamp, or other parts' voltage ratings.
Then by knowing the peak it can be determined to be working and safe to hook up the amp, then with amp outputting to the speakers the actual load on the PSU can the load under which a second PSU voltage measurement is taken.
Old 6th September 2008, 03:57 PM   #22
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You can see some real life measurements here: http://www.diyaudio.com/forums/showt...40#post1521340
The transformer was 300VA, 2 x 22V AC Plitron.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th October 2008, 11:32 PM   #23
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
Thanks for the help!
Old 12th October 2008, 11:27 PM   #24
i have 2 25-0-25 100W toroidal transformer and i want to use one / channel.
i see a lot of design that use 0-25 transformers (without CT) wich will be the diference?
will be better to use 0-25 instead 25-0-25 ?
Old 13th October 2008, 12:26 AM   #25
use either a dual secondary 0-25, 0-25Vac
or
a centre tapped secondary 25-0-25Vac.
A single secondary will give a single polarity supply and you then have to redesign your amplifier to operate from a single polarity supply. See the datasheet for details.
regards Andrew T.
Old 24th October 2008, 03:05 PM   #26
0-25 transformers (without CT) will give you the option to use separate bridges, with CT it's not possible.
Depending on your setup, this may be advantage or not.
http://www.diyaudio.com/forums/showt...ht=#post331061
www.audiosector.com
Old 2nd November 2008, 10:37 PM   #27
Using 1 CT for each channel will improve anything? or just will loose my money doing that?
I want to use dual rectifiers, but i dont have 0-25 0-25 Secundary, i just have 2 CT 25-0-25.
Old 2nd November 2008, 10:40 PM   #28
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Dual mono does bring a definite improvement in my experience. If you already have the transformers, it won't cost you much more.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 3rd November 2008, 01:56 AM   #29
wow, nice
btw, how can i measure if the gain and output power of both Mono amps are the same? :S
Old 3rd November 2008, 02:01 AM   #30
See the link in Post #22
www.audiosector.com
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 03:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 06:20 AM
Page generated in 0.08603 seconds (77.69% PHP - 22.31% MySQL) with 11 queries
