Chip amp power supply- a beginners guide
Old 20th February 2009, 05:25 PM   #241
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Hi Richard,
Yes both zeners face the same way. I think my problem is I didn't have any J309 and I have used a different N-Fet. I will have to order some..I managed to get all the transistors from Maplins.
It looks as if your centre pin on the J309 goes to the 1k resistor?
Old 20th February 2009, 06:13 PM   #242
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Originally posted by audio1st
Hi Richard,
Yes my 1k resistor goes to the centre pin (source) of the J309
Old 20th February 2009, 06:23 PM   #243
audio1st's Avatar
I think the 1k should go to Gate and the 130r goes to Source.
Old 20th February 2009, 07:29 PM   #244
audio1st's Avatar
Got it sorted, V- so far, forgot to connect the reservoir cap. Stable now..
25v transformer, with 27v Zener ends up with -25vDC after all the regulation.
26.5v across Zener.
11v across Fet
0.8v across R2.
FET connections, G to 1k, D to Zener and S to 130r...
Old 20th February 2009, 07:55 PM   #245
Tripmaster's Avatar
26.5v across Zener.
11v across Fet
0.8v across R2.
Audio1st! Its a marathon not a sprint
So is the schematic wrong, or am I misreading it?
Well done BTW
Old 20th February 2009, 08:12 PM   #246
audio1st's Avatar
Hi Richard,
Schematic is right, I have used a different Fet, opposite pin out to the J309, makes no difference as long as you follow the correct G,D,S connections.
You may have damaged your J309, but you might as well swap the 130r and the 1k with each other and see if it helps?. My zeners are 1.3W from Maplin. Have you installed a new Zener yet?
Old 20th February 2009, 09:03 PM   #247
Tripmaster's Avatar
Hi Richard,
I'm just about to
Old 20th February 2009, 11:01 PM   #248
Tripmaster's Avatar
I have replaced the Zener, J309 and R2 resistor
For the purpose of this test I have kept R2 (130R) connected to the Gate, Drain is connected to Zener and Source to 1K.
Here are the readings...
Across R2 (130R) =34.8v
Across Zener=27v
Gate (Connected to R2)=34.8v
Source (Connected to 1K) =33.1v
Drain (Connected to Zener) =27v
Output 24.9v
The light bulb illuminates for a second and goes out immediately. Before the component swap the filament in the bulb would flicker dimly whilst the on button remained pressed
If some of these readings are too high I will swap the 1K and R2 resistors around.
Old 20th February 2009, 11:52 PM   #249
audio1st's Avatar
Hi Richard,
Your R2 wont last long with 35 volts across it..
Swap them over and see what you get, if no better you must have still got a short somewhere.?
Old 21st February 2009, 09:35 AM   #250
Tripmaster's Avatar
I have swapped the two resistors around so the R2 is 1k and the resistor before it is 130R
The voltages are now...
Across R2 (1K) =34.5v
Across Zener (27v) =28.1v
Gate=34.3v
Source=33.3v
Drain=28.3v
Output 25.8v
The output voltages have increased and the voltage is still to high across R2.
I will check again for shorts
Chip amp power supply- a beginners guideHide this!Advertise here!
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 03:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 06:20 AM
