Chip amp power supply- a beginners guide - Page 24 - diyAudio
Old 20th February 2009, 08:58 AM   #231
stick the red DMM probe on the band end. Stick the black probe on the other end.
Is the DMM reading positive or negative?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th February 2009, 09:36 AM   #232
Tripmaster's Avatar
hi andrew
maplin have some 0.5mw 27v zeners at my local store
will these be ok?
Old 20th February 2009, 09:51 AM   #233
500mW 27V need about 1.9mA to exceed 10% of rating. go for it.
Do you see why I keep repeating that newcomers should build an unregulated supply for their first project.
Keep that first amp project simple. Get it working.
regards Andrew T.
Old 20th February 2009, 12:13 PM   #234
Puffin is offline Puffin  United Kingdom
KISS!
Old 20th February 2009, 12:37 PM   #235
audio1st's Avatar
Hi Richard, I have tried to make the same PS to see where the problem may be?
First the J 309, the gate is not the centre pin Here
I used 1.4W zeners and they don't work right with the J309. I will have to try lower wattage version as Andrew suggested..
Old 20th February 2009, 12:39 PM   #236
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
I go over this sort of circuit with the meter, checking that each connection, of each component is connected to what it should be, and perhaps more importantly, that it is not connected to anything that it shouldn't be.
That can be a long and laborious job, but usually results in the circuit working first time.
Like Barry, my suspicion was that there was a short somewhere. Barry pointed pointed out one possibility, but there may be another one or two!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 20th February 2009, 12:51 PM   #237
Tripmaster's Avatar
Hi Andrew
Iíve built a LM317 regulated supply, but this is my first project by following a schematic, and first with discrete components.
I have really appreciated all the help so far and I have learnt a lot from this exercise as Iím sure others will have too.
A large number of users on this forum may be quite technical but will have had little experience in electronics. Most wouldnít even try to have a go if it wasnít for the likes you, Audio1st and Nick to name but a few.
Old 20th February 2009, 02:59 PM   #238
Tripmaster's Avatar
http://www.maplin.co.uk/Module.aspx?...=19089#specifi
Part No. N42BZ 27v
Old 20th February 2009, 03:56 PM   #239
mjf is offline mjf  Austria
hello.
may i have a question to the schematic in post 204?
why do both voltage rails use the equal type (n-channel) fet?
at the pos.rails the drain is connected to them,in the neg. side the drain is connected to the z-diode.
greetings..........
Old 20th February 2009, 04:15 PM   #240
Tripmaster's Avatar
Hi Barry
Do you have your Zener cathodes pointing in the same direction for both -v and v+ supplies, and are they the same as mine?
Richard
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 02:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 05:20 AM
Copyright ©1999-2017 diyAudio
