Chip amp power supply- a beginners guide
Old 17th February 2009, 10:48 PM   #191
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Hi Richard,
This is the link I can't see in your picture, is it underneath?
If so, any chance of a bottom shot
Old 17th February 2009, 10:51 PM   #192
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Originally posted by audio1st
Hi Richard,
Well spotted! but ive just soldered the link in place
Old 17th February 2009, 10:57 PM   #193
Tripmaster's Avatar
Remember I get 27v from the Zener and 34v from the first BD140 (-v)
So I am guessing the problem is between these two points.
I haven't had much time on it tonight because the wife wanted me to watch 'Mistresses'...such a shame
Old 17th February 2009, 11:15 PM   #194
Tripmaster's Avatar
Tidy on top...messy on bottom!
This picture was taken before I added the link to the collector pin of the BD912, I have only added it to the -v side for the time being.
There is a blob of solder on the -v side where the zener and the J309 meet....I carelessly soldered the J309 one row too high and then had to bridge the connection.
I'm off to hit the hay!
Old 17th February 2009, 11:21 PM   #195
audio1st's Avatar
I can see no break in the copper from in to out?
Old 17th February 2009, 11:39 PM   #196
audio1st's Avatar
Richard,
Cut at Black marks and link at Red..
Old 18th February 2009, 07:24 AM   #197
Tripmaster's Avatar
Richard,
Thanks Barry
I will check again this evening.
I have added a link after the BD912, between the collector pin and v-
This was added just before this photo was taken
Old 18th February 2009, 07:30 AM   #198
audio1st's Avatar
Hi Richard,
The Link must be just before the 911 and 912. Not after..
Old 18th February 2009, 08:09 AM   #199
audio1st's Avatar
I hope this shows it better..
Old 18th February 2009, 09:01 AM   #200
R.I.P.
Originally posted by Tripmaster
I am using a 40w bulb for this test
Q1> Is the bulb off when there is no load and the ON switch is held down?
[COLOR=black]A1> The bulb lights for less than a second
Q2> Does the bulb react in any way when you connect a load and hold the ON switch down?
A2> As above
Q3> Can you arrange a big load to light the bulb? and does it o off when you press the BYPASS?
A3> I placed a 1K3 resistor between V- and Ground, the bulb lights as above and the bypass switch has no effect.
this is not right.
The bulb must be off when both switches are off.
The bulb must not flash, not even briefly nor dimly, when the ON switch is pressed and there is no load.
The bulb must go out, if it is already glowing or lit, when the bypass switch is pressed.
A big load would be a kettle, fan heater, iron, toaster etc.
regards Andrew T.
Chip amp power supply- a beginners guideHide this!Advertise here!
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 02:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 05:20 AM
