Chip amp power supply- a beginners guide
Old 16th February 2009, 11:35 PM   #181
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Here are a couple more close-ups
Old 17th February 2009, 09:08 AM   #182
AndrewT is online now AndrewT  Scotland
one switch of ON/OFF, the other is the bulb BYPASS.
Is the bulb off when there is no load and the ON switch is held down?
Does the bulb react in any way when you connect a load and hold the ON switch down?
Can you arrange a big load to light the bulb? and does it o off when you press the BYPASS?
regards Andrew T.
Old 17th February 2009, 09:18 AM   #183
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Sounds to me like you have a short connecting the input supply to the output! Double check you have not left any tracks linking parts of the circuit where they are not meant to.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 17th February 2009, 11:10 AM   #184
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Hi Richard,
Congratulations on having the same problem on both rails
I'm with Nick on the uncut tracks.
I bet your sick of looking at it
Old 17th February 2009, 12:45 PM   #185
audio1st's Avatar
Richard,
Check the cuts around the BD911..
Old 17th February 2009, 01:31 PM   #186
mjf is offline mjf  Austria
hello.
picture post 181 looks like there is a res solderd to the screw.....isn't the screw a collector pin? perhaps you connected the collector with the emitter by a res (100 ohm?).......
perhaps it can help............
greetings............
Old 17th February 2009, 03:00 PM   #187
Tripmaster's Avatar
Originally posted by mjf
hello.
A trick of the light
Old 17th February 2009, 03:21 PM   #188
Tripmaster's Avatar
Hi Andrew
When I connect the light bulb and press the on button the light, lights up for a second and then goes out. This happens when I have a 230R resistor between V- and ground
I will check the other combinations tonight and will also increase the value of the test resistor
Richard
Old 17th February 2009, 03:22 PM   #189
Tripmaster's Avatar
Originally posted by audio1st
Richard,
Will do!
Old 17th February 2009, 10:57 PM   #190
Tripmaster's Avatar
I am using a 40w bulb for this test
Q1> Is the bulb off when there is no load and the ON switch is held down?
[COLOR=black]A1> The bulb lights for less than a second
Q2> Does the bulb react in any way when you connect a load and hold the ON switch down?
A2> As above
Q3> Can you arrange a big load to light the bulb? and does it o off when you press the BYPASS?
A3> I placed a 1K3 resistor between V- and Ground, the bulb lights as above and the bypass switch has no effect.
Chip amp power supply- a beginners guideHide this!Advertise here!
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 03:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 06:20 AM
