Chip amp power supply- a beginners guide
Old 15th February 2009, 09:50 PM   #171
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Hello
I finally got around to finishing one of these power supplies.
I am feeding 25v secondaries into this power supply via a bridge rectifier. I have connected a 230R resistor between either Vout + or Vout - and I'm getting a reading of 36vdc.
I am using a 27v zener to set the voltage, would I be right in thinking the voltage is too high?
Richard
Old 15th February 2009, 09:58 PM   #172
R.I.P.
hi Trip,
what have you built?
Help us to help you.
regards Andrew T.
Old 15th February 2009, 10:15 PM   #173
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Yes Richard, you should be getting around +/-27v. Sounds like you could have a short somewhere allowing the full unregulated voltage through to the output.
Andrew, he is building the Pedja Rogic discrete regulated PSU described here (second diagram down).
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 16th February 2009, 07:23 AM   #174
R.I.P.
Hi trip,
The two followers each drop ~0.6V. the output should be ~27-1.2 ~25.8Vdc.
Start by measuring the voltage from ground to all the components and list them here. Do one channel only. Check to see if any component gets hotter than the rest. The pass transistor should be cold if it is not dropping any voltage.
Is the 230r load resistor getting VERY hot? 36V across 230r is 5.6W and that resistor looks like it might be a 1 or 2W carbon composition. Is it still drawing any current?
regards Andrew T.
Old 16th February 2009, 08:30 AM   #175
Tripmaster's Avatar
Originally posted by AndrewT
Hi trip,
Hi Andrew
I will have a look tonight and will post the results.
The resistor on the output got very hot last night, I turned the power supply on this morning and noticed the 3A fuse in the ‘light bulb tester’ plug top had blown.
I’ve lost count the number of times I have checked this board prior to powering up!
Richard
Old 16th February 2009, 08:39 AM   #176
R.I.P.
is your light bulb tester properly wired up?
It should be unlit when no load is present.
If the bulb lights when you insert a big load into the output socket then it's probably right, but it should never blow a 3A fuse, that's indicating the bulb passed more than 700W!!!
regards Andrew T.
Old 16th February 2009, 09:07 AM   #177
Tripmaster's Avatar
As sure I was about the power supply
I have bought the components to make the Nick’s latest light bulb tester (including on-off testing switches) I think this should be the next project!
Old 16th February 2009, 10:09 PM   #178
Tripmaster's Avatar
Hi
I have attempted to assemble another light bulb tester this evening.
Would you mind checking my wiring, I think its ok?
Richard
Old 16th February 2009, 10:17 PM   #179
Tripmaster's Avatar
OK, right then...I have connected the light bulb tester to my power supply and I get 34.2vdc from the output. I then measured the voltage at the 27v zener (pictured below) this read 26.63vdc.
When ever I press the 'on button' on the light bulb tester the bulb glows for a second
Old 16th February 2009, 10:30 PM   #180
Tripmaster's Avatar
The voltage remains at 26v up to and including the base pin of the first BD140 transistor. The collector and emitter read 34v
Chip amp power supply- a beginners guideHide this!Advertise here!
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 02:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 05:20 AM
