Chip amp power supply- a beginners guide
Old 27th January 2009, 10:23 PM   #131
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Thanks Nick
Old 28th January 2009, 12:08 AM   #132
raypalmer is offline raypalmer  Canada
raypalmer's Avatar
Originally posted by AndrewT
Hi Ray,
you've got a dual polarity supply from dual secondary transformer.
Middle connection is treated as zero volts.
The other two connections from the PSU are +33Vdc and -33Vdc.
All normal for this 24Vac transformer.
Originally posted by audio1st
Hi Ray,
It looks as if you have 2 white wires at V- and 2 red wires at V+..
I cant see where PG- and PG+ are connected, have you just tied them together?
They need to connect to the AMP board ground..
Please let us know how you have connected these wires.
Barry..
Sorry I'm so dumb, you guys are gents for helping me so much.
I've got two wires on V+ and V-, PG+ and PG- are wired to the ps chassis ground, which is in turn wired through the connector cable to the amp boards star ground and by way of that to the chassis ground for the amp enclosure. Here comes a diagram:
Wherever you go there you are.
Old 28th January 2009, 12:14 AM   #133
raypalmer's Avatar
Hi Ray,
So Andrew...
In order to treat the middle connection as zero I do this (see crude diagram), right?
Is only having one of two holes in AC1/AC2 going to work?? Doesn't that defeat the rectifier?
Old 28th January 2009, 07:24 AM   #134
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Hi Ray, the second picture is wrong.. The layout you have at the moment should work but may hum.
Below is my suggestion..
We may have to look at the Amp boards next?
Barry,
Old 28th January 2009, 01:39 PM   #135
raypalmer's Avatar
I'll post it when I get back from work. Your beautiful diagram puts me to shame
So by only using one of the V+ and V- pads, and splitting it across the two amps, I'll halve the voltage? I was beginning to think I'd need to buy a transformer with lower voltage.
Old 28th January 2009, 01:52 PM   #136
R.I.P.
sharing the PSU currents across two amplifiers has nothing to do with halving the PSU voltage.
The PSU has two halves each half has an output voltage ~ 1.5Tines the Vac of each transformer secondary Series connect the two output voltages at the rectifier PCB and you get +-Vdc ~= 1.5 times Vac + Vac.
You can use either a single rectifier to achieve this +-Vdc or you can use dual rectifiers to get similar +-Vdc.
The single rectifier version series connect trhe secondaries before the rectifier and can use a dual secondary transforme ror a centre tapped transformer.
The recent diagrams posted here show a dual rectifier version that must use a dual secondary transformer. The series connection of the supplies is after the rectifier in this case.
regards Andrew T.
Old 28th January 2009, 04:01 PM   #137
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Chip amp power supply- a beginners guide Send a message via AIM to Peter Daniel
Barry,
That's a beautiful diagram and I was using such setup successfully in AMP-1 for many years. That amp was dual mono with separate power feed to each channel.
When I tried to use similar approach in Patek or an Integrated Amp some people reported hum problems, so I modified ground wiring and that was better.
So if would be so kind, can you adjust the diagram in a way that OG points (on amp boards) are connected together and PG- and PG+ wires from power socket connect centrally to that connection, like in a picture here: http://audiosector.com/images/patek2/patek2_01.jpg
To order kits contact me through forum mail.
Old 28th January 2009, 05:50 PM   #138
audio1st's Avatar
Hope this is how you recommend Peter?
Old 28th January 2009, 07:07 PM   #139
Yes indeed, that's what I recommend now.
Old 28th January 2009, 10:55 PM   #140
raypalmer's Avatar
Okay... I'm sorry I'm fully overwhelmed now. My 0-24, 0-24 Transformer.... How do I wire this with my power supply so that I will get 24V x 1.4 rather than 48v x 1.4??
All I need is to have the right amount of voltage to my amp and I believe I'm off to the races.
Chip amp power supply- a beginners guideHide this!Advertise here!
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 02:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 05:20 AM
