Chip amp power supply- a beginners guide
Old 26th January 2009, 05:26 PM   #101
audio1st is offline audio1st  United Kingdom
audio1st's Avatar
Originally posted by raypalmer
I've got it plugged into the bulb tester at all times until I know forsure I've got a healthy device. As for the xformer, I tested it as suggested before installing it in the box and it worked like a peach.
Click the image to open in full size.Click the image to open in full size.
I may need to use a non-cellphone camera...
Hi Ray, I looked for the colour code of your xformer on line.
I found the diagram below and if it is correct, your primary is wired wrong. You have orange and yellow connected together and red / brown connected together??
Old 26th January 2009, 06:04 PM   #102
if the primaries are wired out of phase then the transformer alone (open circuit secondaries) will have the test bulb brightly lit.
If the primaries are in phase then the test bulb will not even glow dimly.
regards Andrew T.
Old 26th January 2009, 07:32 PM   #103
raypalmer is offline raypalmer  Canada
raypalmer's Avatar
Yeah, I had that same doubt so I switched the primaries a few days ago, but it lit up my bulb, at present the bulb tester is totally dark.
Wherever you go there you are.
Old 26th January 2009, 07:58 PM   #104
audio1st's Avatar
Hi Ray, if the diagram I posted is the same as the one on the side of your xformer, then you should connect the Brown/Orange to neutral and the Red/Yellow to Hot..
Old 26th January 2009, 10:31 PM   #105
raypalmer's Avatar
I'll give it a go tonight when I get home. Will post results this eve.
Old 26th January 2009, 10:34 PM   #106
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
I have recently built Pedja Rogics regulated power supply for a TDA1543 DAC
and now fancy having a go at CarlosFMs regulated snubberized power supply for my LM3886 chipamp.
I have started to layout the components on strip board before I start to solder. I notice the schematic recommends use of MKT decoupling capacitors, would resin dipped ceramic decoupling capacitors work OK in these positions?
I plan to use 10000uf BHC slit foil reservoir capacitors on these boards and wondered if there was a benefit increasing the capacitance from 10000uf to say 20000uf at a later date? (I thought I might add them where the rear capacitor is lying)
N.B The voltage regulators in the photo are LM317s and these will be replaced with LM338Ts, the capacitor in the rear of the photo is purely there as a counter weight.
Thanks again Nick for putting together a great website
Richard
Old 26th January 2009, 10:45 PM   #107
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Richard, my (clear) preference is for the Pedja Rogic discrete regulated supply for the GC! And I reckon 10,000uF is enough for a GC but as ever, I won't discourage responsible experimentation!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 26th January 2009, 11:03 PM   #108
Tripmaster's Avatar
Yessss SIR!
I know, but I have all of the components and I understand where these components go...I'll have a go at the discrete version later.
Do you fancy doing a nice little layout drawing of the discrete supply?
Richard
Old 26th January 2009, 11:12 PM   #109
Nuuk's Avatar
I do one day but I don't have the time right now. IF I can find time to take a photo of mine I will do that. It's a fairly simple circuit and shouldn't present any problems.
Alternatively, see if you can get PCB's from Pedja at Audial for his regulated PSU.
So the supply you built for your 1543 wasn't Pedja's discrete, it was based on LM317/337?
Old 27th January 2009, 12:36 AM   #110
raypalmer's Avatar
Okay audio1st I owe you a coke.
Now I think my secondaries are incorrect. Are they??
Chip amp power supply- a beginners guideHide this!Advertise here!
A Beginners Guide to Enclosure Alterations Bork Multi-Way 7 12th January 2009 03:10 AM
beginners ecl82 power supply emil_86 Tubes / Valves 15 25th September 2004 06:20 AM
Copyright ©1999-2017 diyAudio
