two single secondaries, two rectifier boards lm4780 kit
Old 21st August 2008, 02:14 PM   #1
gbolly is offline gbolly  United Kingdom
Default two single secondaries, two rectifier boards lm4780 kit
hello guys,
i recently made a mistake and bought a pair of 300va 23v toroid transformers on ebay without reading the description properly only to find out that they each have single secondaries.
i know thus far that you can wire both transformers together by connecting together the two primarys and then have two seperate secondaries to work with a single peter daniel rectifier board.
my questions are,
could i connect a second rectifier board in parallel to the first so i can get to connect a second amp board (im aware i could get hums or buzzing from ground loop issues)?
would having seperate star grounds for each of the rectifier board/amp board combos make any potential ground loops go away or at least be minimized
i :
am using the peter daniel lm4780 kit
plan on actively biamping a pair of mordaunt short ms908 floorstanders (i doubt 1 amp board will be enough for the two, want to assign one amp board to each speaker)
not fussed too much about dual mono configuration for now, just want to maximize the two traffo's.
thanks in advance
Old 21st August 2008, 02:28 PM   #2
pacificblue is offline pacificblue  Germany
Default Re: two single secondaries, two rectifier boards lm4780 kit
Originally posted by gbolly
my questions are,
You could, but you only need to do that, if the current rating of a single board is too low for two amps. If it isn't, so you can run your two amps from one rectifier board.
Probably not.
Old 21st August 2008, 07:00 PM   #3
thanks
Old 22nd August 2008, 02:37 PM   #4
300VA 23Vac gives 13amps from that single winding.
It is very unlikely that a single wire is used for 13A. Much more likely is that it is bi-fillar or tri-fillar wound. 13A requires somewhere around 2.2 to 2.3mm diameter copper single core, or two cores of 1.6mm diameter, or three cores of 1.3mm diameter.
Open up the outer insulation and look at the connection where the winding meets the lead out.
If it's bi-fillar then add on separate lead outs for each wire in the secondary.
If it's tri-fillar add on a complete 23Vac winding and make a four secondary transformer. This allows complete isolation for two channels.
regards Andrew T.
Old 22nd August 2008, 09:11 PM   #5
Redshift187 is offline Redshift187  Canada
Is this also the best way for me to wire a single 300VA 18V+18V to a pair of rectifier boards?
Old 23rd August 2008, 08:59 AM   #6
no, too much work when the lead outs are already there.
However, if the leadouts are solid core then it is worth the effort to open up and replace these with flexible leadouts to permit experimentation of orientation of the transformer.
regards Andrew T.
two single secondaries, two rectifier boards lm4780 kitHide this!Advertise here!
Need some help: one vs. two rectifier boards? ebenai Chip Amps 4 25th May 2007 12:49 PM
2 secondaries ,2 rectifiers and 2 regs, - rectifier overheats Nordic Power Supplies 4 20th March 2007 09:34 AM
how to Using single secondaries transformer for snubber psu triast Chip Amps 18 10th September 2006 11:40 AM
Trafo- 225VA , single 117V primary, Dual 40V secondaries Illusus Swap Meet 3 11th December 2003 05:07 AM
Copyright ©1999-2017 diyAudio
