| Chip Amps Amplifiers based on integrated circuits |
Here's a newbie question I'm trying to answer - how much feedback (in decibels) is around a typical opamp? Lets take for instance an opa2134 - here is the datasheet . The chip has 120dB open loop gain. At the top of page 5 are a couple graphs showing open and closed loop behavior. Lets assume the chip is operating at a voltage gain of 100 (the top line in the closed loop graph). That is equivalent to 40dB of gain. Would the equation for NFB in decibels = 10log(120/40) = 4.8dB? That doesn't seem right - I calculated it another way and got about 60dB.. Anyone have the answer? Thanks
double complete rainbow all the way!! |
#2 | |
120dB - 40dB =80dB feedback this is also frequency dependant
Just because you can't hear it doesn't mean no one can. |
#3 |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
Hey, thanks.
Here's one that might be a little harder - how much NFB is there around a current feedback opamp, such as the AD815 ? There is no stated open loop gain, and page 10 describes the chips gain structure some, saying the amps gain is bandwidth independent, more or less. Lets say I'm using a voltage gain of +5...
#5 | |
gain of x5 = +14 dB It looks as AD815, current fb opamp, has got open loop transimpedance .. which seems like being sorta open loop gain In case of AS815, this is 120 dB .. in lower audio band. Now a transimpedance is load dependent so the gain depends on how much impedance the output will see This load impedance of course, as in any feedback amplifier, will include the feedback resistance. Lower load resistance (impedance) = lower open loop Voltage gain. The formula is probably quite simple to find out the Open Loop Voltage gain, for any load impedance. I will wait for the audio mathematical guys ( proud Electronics Engineers and higher = EE and EE+ ) to come here tell us these simple formulas. Thanks LineupSee my attached figure from AD815 datasheet
lineup |
| CF-Opamp | Onvinyl | Parts | 6 | 3rd April 2006 03:09 PM |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| Opamp Vcc | computeruser | Solid State | 5 | 13th October 2005 03:27 AM |
| Regulate the psu of a power opamp with a similar power opamp? | Franz G | Chip Amps | 34 | 19th October 2004 10:49 AM |
| opamp-amp | petera | Solid State | 5 | 4th December 2001 11:39 AM |
| Page generated in 0.09117 seconds (72.63% PHP - 27.37% MySQL) with 11 queries |
