TDA7386 Car Amp
TDA7386 Car Amp
Old 21st May 2009, 12:36 PM   #21
pacificblue is offline pacificblue  Germany
Originally posted by strajo
Good news : when I removed pwr amp inputs, and power up only TDA, there is no noise at all.
Can you connect a headphone to the preamp output to find out, if the hum already comes from there or if it really appears only, when preamp and power amp are connected to each other?
So, remember those transformers from pci modem cards...I will surely remove them, and for RCA inputs, considering balanced line driver and receiver from http://sound.westhost.com/project51.htm.
What do you think..will that be helpful.
Depends on the reason for the hum. If it is a ground loop and you can break it that way, yes. You would have to replace the RCA inputs with XLR inputs, which are bigger and maybe not convenient in a car.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 26th May 2009, 12:13 AM   #22
strajo is offline strajo  Serbia
Hi, it is been a while...some job problems.
I solved my noise problems by adding balanced line receiver circuit to preamp input, connecting unbalanced RCA ground to receiver's cold (-IN) and signal wire to receiver's hot (+in). Schematics I used is from http://sound.westhost.com/project51.htm. Only thing I changed is removing 3k3 resistor since signal level was little lower than expected. After all, that resistor is optional, as written in text...
Right now, I'm listening my modified premp (maked new one after burning old), feeling happy...what else to say.
further plans:
1. Passive cooling
I don't like fan solution specialy in car...dust...maintaince. And it looks like that Pentium IV square heatsink isn't large enough (400cm2, even more). It becomes hot (but Il can hold it in hand) at 50 and above volume present. Of course, fan cools it down very rapidly, but passive is passive. Maybe, its wings (don't know how to say...fins?) are too close each other, so free air flow is reduced that way. And, again, after all, it is designed for fan forced air flow.
On the other hand, here is very hard to find larger heatsink, like looking for Holy Grail...some alutronics models, not very wide choice at all. And they are very expensive. So I decided to try building one from 2mm alu sheet like on http://sound.westhost.com/articles/diy-heatsink.htm
...but smaller variant, of course. I'll post results, like always. I already have 1x2m alu sheet, and need some time for cutting, drilling...
2. car testing - real environement
3. Single board layout - preamp, amp, pwr control and regulation on single one side board...compact design.
and that would be it...
best regards folks, and sorry for long posting...
TDA7386 Car AmpHide this!Advertise here!
PCB for TDA7386 Amplifier enecumene Chip Amps 2 23rd April 2016 07:51 AM
Help with TDA7386 jorge_rc Chip Amps 8 20th June 2012 07:46 PM
TDA7386 Problem please help Brownstocker Chip Amps 5 28th January 2008 10:02 PM
Tda7386 koloko Chip Amps 1 18th June 2007 08:25 AM
Problem with TDA7386 SideWinder Chip Amps 0 24th May 2004 10:13 AM
