| Chip Amps Amplifiers based on integrated circuits |
Hello all,
I have a great phono preamplifier that has balanced I/O. My phono is a MM project debut II and it has unbalanced rca outputs. I was wondering if there is a way to connect directly the unbalanced output of the phono to the balanced input of the preamp. And also vice versa at the preamplifier output end to the next unbalanced stage. My will is not to use opamps and to keep the circuit as simple as possible in order not to compromise the sound fidelity of the preamplifier. Thank you all.
Great DIY site: http://www.neazoi.com |
#2 |
#3 |
I have seen your design in another topic but, how about sound performance? Is there any way to achieve this conversion without an active device?
#4 |
Did it Himself
A transformer would be the only passive way.
And just because sumething is the simplest way possible or passive, doesn't mean it's the most accurate or neutral or best.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
Thank you very much.
| Unbalanced to balanced input conversion? | SQLGuy | Solid State | 53 | 19th October 2009 01:39 AM |
| Line input transformer for unbalanced to balanced conversion | okapi | Chip Amps | 23 | 12th January 2008 05:29 PM |
| using a transformer for balanced to unbalanced conversion | h_a | Analog Line Level | 47 | 9th January 2007 10:16 AM |
| unbalanced/balanced/unbalanced conversion using transformers | vladimir | Solid State | 10 | 27th February 2003 06:54 PM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| Page generated in 0.07612 seconds (73.35% PHP - 26.65% MySQL) with 10 queries |
