diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Snubberized Regulated Supply (http://www.diyaudio.com/forums/chip-amps/127344-snubberized-regulated-supply.html)
Dino-Indo 1st August 2008 01:38 AM
All,
I'm planning to build a snubberised regulated PS as per Carlos FM design for my next LM3876 project.
Using the Carlos FM PS circuit, would it be beneficial for the sound quality if I instal 2 (two) 3Amp EI transformers instead of one trafo only?
Many many thanks in advance!!
Nuuk 1st August 2008 07:22 AM
In my opinion yes, dual mono is always an improvement. Of course how much of an improvement depends on the rest of your system! ;)
Dino-Indo 2nd August 2008 04:16 PM
Hi Nuuk...
Thanks for your advise:) ... in deed the overall system does count.. plus the listening environment too
Couple of questions:
1) Instead of LM338.. can I use LM317? Honestly, this type is what I got for the time being... :confused:
2) I try to follow the component layout of regulated PS from your website :D ... but a bit confused.. So, the negative rail will use adjustment leg of the regulator, right(not the output leg)? :confused:
Look forward to have your further advise,
Kind regards,
AndrewT 2nd August 2008 04:48 PM
did Carlos specify the 338?
using a 317 will not be as per Carlos!
Dino-Indo 2nd August 2008 05:01 PM
Oops... :clown:
My apologies.. :clown:
I shouldn't ask... :clown:
Nuuk 2nd August 2008 06:17 PM
LM317 won't handle the current. Stick to the exact circuit or you could land up in trouble! ;)
BTW, I personally prefer the Pedja Rogic regulated GC.
Inch-o 6th August 2008 02:36 PM
The LM338, is a 10Amp max, 7Amp continuous positive adjustable voltage regulator.
It is the simplest way to implement a high current power supply. If you want to use the 317, the circuit will be much more complicated due to the need of adding an external power transistor....
Dino-Indo 6th August 2008 03:00 PM
Hi Nuuk.. Hi Inch-O..
Many thanks for the clarification and advise. :)
Will switch to LM338 accordingly then... )
Kind regards,
Dino Ary
Nuuk 6th August 2008 04:00 PM
Actually, if you want to use LM317, it is not out of the question. Have a look here .
Dino-Indo 6th August 2008 04:59 PM
Hi Nuuk..
Again.. many thanks for your help..
Very interesting and tempting to try..
Kind regards,
Dino Ary
PS: Another challenge though... hehehe... quite difficult (and might be expensive) to get tantalum caps as well as some of the transistors in Jakarta...
Resources saved on this page: MySQL 18.75%
