| Chip Amps Amplifiers based on integrated circuits |
Has anyone built the discrete buffer (three transistors - Andrew Rothwell) from decibel dungeon ?
I've simulated it and it seems to work well. I'm using 3 C549B transistors However converting over strip board i get very little audio output into a 6ohm speaker. I also get a 'cloudy' sin wave at the input and output (function generator at the input). What could be causing this? Can anyone help me I've been over the stripboard several times and can't find anything wrong. thanks |
#2 |
post a close up pic of both sides of the PCB and the whole preamp.
regards Andrew T. |
#3 |
This isn't going to help, but I gave up on this buffer. I tried several builds on stripboard, and then gave up.
I think that Nordic may have mentioned that he had trouble with it as well. Good luck... |
#4 |
well i've got it working, though i do get quite abit of ground hum (which can be sorted).
Am i wright in say that this buffer doesn't actually add any gain? and is at unity? |
#5 |
That's correct, it is a unity gain buffer.
I've built several versions with no problems like hum. There is a bit of DC on the input and I got very small clicks as I turned the stepped attenuator.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#6 |
look at it with a scope it looks like unity. When i compare it with my laptop straight to a speaker vs. laptop->buffer->speaker it seems to attenuate the sound. Its louder with out the buffer inline.
Is this correct ? Nuuk do you have a pcb version? |
#7 |
I can't comment on the loudness issue as I have not experienced it.
No, I don't do PCB's, and this circuit is so simple it hardly warrants one.
#8 |
Yep, I gave up on that buffer too.. after numerous diffirent PCB's, PSUs, and transistors, I could not get it to run stable for more than 5 minutes...
I have a friend who uses it sucsessfully though... Then did the Pedja Rogic buffer, and was about as impressed as I get. Since then moved to an amp that does not need the extra distortion of another stage slapped infront of it... P.S. a discrete unity buffer will put out slightly less than the input... |
#9 |
Magneto the Gravity Man
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#10 |
Good old B.I.Y. ?
Buy it yourself. |
| FS: Opamps, Buffers, etc. | luvdunhill | Swap Meet | 3 | 3rd April 2009 04:16 PM |
| Cascode Buffers | acoustixman | Solid State | 43 | 26th August 2008 04:04 PM |
| FS : OPAMPS & Buffers | dtm1962 | Swap Meet | 2 | 6th October 2006 07:43 PM |
| Mini Portable Headphone Amplifier, with Discrete Diamond Buffers | cetoole | Headphone Systems | 3 | 30th May 2006 07:32 AM |
| RAM buffers for DAC? | dorkus | Digital Source | 7 | 21st June 2002 04:14 PM |
| Page generated in 0.09261 seconds (79.87% PHP - 20.13% MySQL) with 10 queries |
