Old 31st July 2008, 02:44 PM   #21
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
Originally posted by Nuuk
Faulty transistor(s)?
i changed the output cap from a 2.2uf to a 4.7uf and that has stop. So i have removed the LP filter.
All i'm getting now is a small pop/thump when i turn the amp on/off.
Would it be worth including a filter in your opinion?
Old 31st July 2008, 03:05 PM   #22
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
More important than my opinion is did you hear any difference when using the LP filter and taking it out?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 31st July 2008, 03:15 PM   #23
Timpert, yes you do have a point. But on the other hand, is the small benefit of a factor 2 in Cgs and Early effect worth the extra transistors? And do we need more headroom than we get with the bootstrapped version? We could always use even higher rail voltage to overcome this problem. I already use +/- 18 V for JFETs alone, with no "cascodes" at all.
Old 31st July 2008, 04:32 PM   #24
timpert is offline timpert  Netherlands
timpert's Avatar
I think so. Not because the benefits are substantial (they are sublte, if audible at all), but because transistors are so cheap that it doesn't hurt to include them. On the other hand, I think that the headroom is not the main issue here, but well behaved clipping is.
Old 31st July 2008, 11:06 PM   #25
juma is offline juma  Serbia
juma's Avatar
The 3 transistor buffer published on Nuuk's site is very simple circuit - an emiter-follower with 5 mA CCS. I experimented a lot with this buffer - different transistors, different CCSs (JFET, LED, 2 diodes...) and it sounded different (nuances) but it worked great every time. One really has to be a master of disaster to mess it up - I guess nothing is foolproof
There are better sounding buffer circuits, but this one can not be beaten for its simplicity/sound quality ratio. Only thing it may need in addition is an input cap (small input DC offset can make some pots crackle).
Nuuk, thanks for great circuit and all patient help you've been providing to less experienced DIYers
Old 1st August 2008, 06:27 AM   #26
Nuuk's Avatar
Thanks Juma, and a reminder again that we owe thanks for the circuit to Andrew Rothwell. As you say, it's a great circuit for trying out different transistors and learning how they sound.
I know we often want to remove any caps in the signal path, but I remember another buffer circuit that AR designed for me. That used DC blockers on the input and output and sounded superb so I don't think we should become too obsessed with avoiding caps when they are needed. In the case of the three-transistor buffer, one on the input will remove and noise caused by the preceding attenuator/pot!
Old 1st August 2008, 06:51 AM   #27
justblair's Avatar
Touche
And yes another big thankyou to Nick at DD for what is to my mind, the very best 'Clone' resource for beginners.
Old 12th August 2008, 09:13 AM   #28
Shoog's Avatar
My last remaining Gainclone which I use on my computer has this buffer on it. The reason its the last remaining gainclone I have is because it sounds really nice.
I had issues when building it. It kept on self destructing until I used some hefty TO220 power transistors. I have it on a seperate power supply. When I discovered +4V on the input I decided it needed an input blocking cap. This is the big down side with this amp as I don't like the fact that it has two caps in the signal path.
This amp is very easy listening with a smooth none fatiguing presentation. I attribute this at least in part to the sound of this buffer.
Shoog
FS: Opamps, Buffers, etc. luvdunhill Swap Meet 3 3rd April 2009 03:16 PM
Cascode Buffers acoustixman Solid State 43 26th August 2008 03:04 PM
FS : OPAMPS & Buffers dtm1962 Swap Meet 2 6th October 2006 06:43 PM
Mini Portable Headphone Amplifier, with Discrete Diamond Buffers cetoole Headphone Systems 3 30th May 2006 06:32 AM
RAM buffers for DAC? dorkus Digital Source 7 21st June 2002 03:14 PM
Page generated in 0.10405 seconds (72.00% PHP - 28.00% MySQL) with 10 queries
