| Chip Amps Amplifiers based on integrated circuits |
Hi i have a strange issue with my gainclone. Schematic attached here. There is a small noise(need to put my ear on speaker to hear) which is not 50Hz hum or high freq buzz but someting in between bout 1Khz/500Hz. This noise occurs when i connect it to my high pass active crossover.
Connected to another source the gainclone has no issue Another discrete amp connected to the same active Xover no issue. Can anyone help. Thanks |
#2 |
In case it can help here is the PCB layout.
#3 |
Your chance to find a solution will increase, if you post the cross-over schematic as well.
You could compare the values of Ri, Rin, Ci and Cin of the gainclone to the corresponding resistors and capacitors of the other discrete amplifier to start with. |
#4 |
the decoupling is not located in the best position. PIN5 desperately needs decoupling. The schematic shows the R+C after the R//L, but the PCB is before. Try changing the two 10R to 4r7 or maybe even 2r7. The 22uF in the NFB is too small. Try 47uF. I cannot see the speaker return.
regards Andrew T. |
#5 |
Hi andrew thanks for the reply will do the mods you advised. pin 5 is actually connected to the 220uF for the +ve rail. Dou you mean add additional decoupling for pin 5?
There is an error in the schematic for the zobel network its correct on the PCB. (Not in original circuit i've added it. Speaker return is the green circle next to the caps the other circle is for power ground. Do you have any other suggestions. Thanks |
#6 |
Thanks pacific for your reply i'll add it soon. The input network and feedback of my discreet amp are:-
Cin- 10uF Rin 15K for input and for feedback Rfeedback=15K Rground=680 and Cground=22uF |
#7 |
Look at the length of the route from PIN5 to the decoupling cap.
You must have the HF decoupling either on or right next to the supply pins. Look also at the Zobel return between the decoupling caps. Could they be picking up output pulses and feeding them back into the supply pins? Remember what Walt J. said "all pins are inputs" Cin=10uF is even worse for allowing voltage to develop across the NFB cap. Cin must limit the passband so that the PSU and the NFB do not have to handle frequencies at or near their poles. The other components are also different from the posted schematic. What are you doing to us?
regards Andrew T. |
#8 |
Hi please find attached the high pass x-over shcematic. I'll be posting PCB layout soon.
#9 |
Put the Zobel on the speaker terminals. I find a 10R 3W + 100nF mylar capacitor work well.
Here is my layout, very similar to yours, except mine is not a true Gainclone as there is only 330uF per rail of capacitance on the board near the chip, with the rest of the capacitance (2x4700uF per rail) is on a seperate board. ![]() For reference, here is the schematic. |
#10 |
Thanks jaycee, but cannot see your layout can you please attach it thanks.
Since its weekend i've been able to trace the source of the issue. Since it was more quiet around i've been able to listen to my discrete and my gainclone both are dead quiet with any external source but the issue i am having is the cross over itself its the one oscillating. Am not an expert with low level circuit layout but i will post schematic and PCB layout here in case anyone can help. Additional improvements to the gainclone are welcome but like am saying its working well and its not the culprit |
| Deluxe Reverb Re-Issue High Frequency Noise. | jordankersten | Tubes / Valves | 1 | 22nd December 2008 09:20 AM |
| Help needed to sort noise issue with amp build | ShinOBIWAN | Solid State | 28 | 7th December 2008 05:29 PM |
| DCX2496 ch6 noise issue | akunec | Digital Line Level | 5 | 30th March 2006 10:10 PM |
| LM3886 p2p - ground issue | Stabist | Chip Amps | 0 | 20th January 2005 02:03 AM |
| Page generated in 0.12724 seconds (71.74% PHP - 28.26% MySQL) with 11 queries |
