| Chip Amps Amplifiers based on integrated circuits |
I've had a search but couldn't really find anything.
What is a good way to step the higher dc voltage used for the amplifier, down to something that can be used for a buffer, i.e 15-20v. Or do people simply use another transformer & power supply thanks ted |
#2 |
best to use a twin secondary transformer of the correct voltage.
Or use a dropper resistor and Zener from your existing HV supply. Or something a bit more complicated. search reg or Vreg or regulator
regards Andrew T. |
#3 |
It might be best to tell us what you realy need. Like how much
current do you need, how tight do you need this voltage regulated, how much noise can you tolerate, do you need a single supply voltage, is it located in the amp ect. |
#4 |
If sound quality is the goal, I recommend a separate PSU for the buffer.
This may give you some pointers.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#5 |
assuming i have a large enough transformer. Is there any 'audio' downside to using one tranny for the amp and the buffer, each with their own PSU feeding from it?
Or if i take a feed from the original PSU output and regulate it down to what i need? i realise more heat will be generated dropping a high voltage. |
#6 |
The problem is when the power amp modulates the supply to the buffer/pre.
You can take separate secondaries off the same transformer and build separate supplies from them.
#7 |
unfortunately my transformer is completely sealed so i'll have to use a regulator
#8 | |
regards Andrew T. |
#9 |
or also a ..:: DC/DC Regulator Module ::..
the truth is somewere |
| Step-by-step ambitious first project! Suggestions? | ledhed2222 | Multi-Way | 7 | 13th August 2009 03:51 AM |
| Step-by-step guide to building a speaker | Richy | Multi-Way | 5 | 5th August 2008 12:48 AM |
| stuffing Mileva: first timer step by step questions | schro20 | Full Range | 7 | 2nd June 2008 05:49 PM |
| how to make spherical wood horns, step by step | angeloitacare | Multi-Way | 0 | 29th May 2007 01:50 AM |
| help design SE preamp with mosfet buffer and step-up transformer. | AudioGeek | Solid State | 0 | 19th January 2005 03:02 AM |
| Page generated in 0.09172 seconds (79.81% PHP - 20.19% MySQL) with 10 queries |
