buffer step down - Page 2 - diyAudio
Old 22nd July 2008, 02:02 PM   #11
r5=680 is too big.
If the supply runs at 24Vdc (this will vary with mains voltage and amplifier load) then you have just 13mA available.
At max mains voltage and min amplifier draw the Zener should be near maximum dissipation. That makes more current available at other operational conditions.
If Zener dissipation is a problem then use a zener+medium power transistor to make more current available for the low level stage when mains is at minimum and amp load is maximum.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd July 2008, 02:31 PM   #12
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
thanks for your help andrew.
can i ask how you calculated 13mA
Old 22nd July 2008, 02:56 PM   #13
17*sqrt(2)=24, [24-15]/680=0.013
regards Andrew T.
Old 22nd July 2008, 03:06 PM   #14
Ted205's Avatar
Thanks for you help
Old 22nd July 2008, 04:11 PM   #15
Ted205's Avatar
Originally posted by woody
It might be best to tell us what you realy need. Like how much
current do you need, how tight do you need this voltage regulated, how much noise can you tolerate, do you need a
single supply voltage, is it located in the amp ect.
I'm making the additional power supply for a discrete buffer (Andrew Rothwell's design from Decibel dungen)
which i need to investigate as to what current is needed.
Old 22nd July 2008, 07:01 PM   #16
the negative and positive rails draw similar current of ~6mA while no signal is present.
But the positive rail current is modulated with a signal passing.
Allow at least +6mA and -6mA.
but probably better to go to +12mA and -6mA, to ensure that current limiting does not occur on asymmetrical peaks. i.e. 0mA to 18mApk in +ve rail and 6mA continuous in -ve rail.
This analysis depends on R1=120r & R2=27k with +-15Vdc to +-20Vdc supply.
I suggest you add an RF filter to the buffer input. 300uS should be sufficient. 470pF & 680r are about right, but there is much leeway in these values.
regards Andrew T.
Step-by-step ambitious first project! Suggestions? ledhed2222 Multi-Way 7 13th August 2009 04:51 AM
Step-by-step guide to building a speaker Richy Multi-Way 5 5th August 2008 01:48 AM
stuffing Mileva: first timer step by step questions schro20 Full Range 7 2nd June 2008 06:49 PM
how to make spherical wood horns, step by step angeloitacare Multi-Way 0 29th May 2007 02:50 AM
help design SE preamp with mosfet buffer and step-up transformer. AudioGeek Solid State 0 19th January 2005 04:02 AM
Copyright 1999-2017 diyAudio
