| Chip Amps Amplifiers based on integrated circuits |
#11 |
yes, add the channel Pd together to get total Pdtot. Yes, the dissipation drops slightly when delivering the last 3dB of output power, when driving a resistive load. Unfortunately driving real speakers, that are reactive, increases the dissipation of the output stage and is much more onerous on the amp reliability. The big saving with sensible unclipped replay is that average levels are, or should be, about 20dB below maximum output. This ensures that the majority of the transient signals pass through unclipped and overall the sound is so much nicer. The downside of this is that the 8W amplifier is outputing just 0.08W on average to your 90dB/2.8V/m speakers and they will sound quite quiet. About the same or slightly lower than a normal conversation between two without raising their voices. OK for background music. If you really want to use single digit output powers then look for affordable speakers that have at least 5dB and preferably 10dB more sensitivity AND 8ohm if driven by a chipamp. |
#12 |
Ok. I think is time to start building and testing results...I have a 13V@10A transformer/rectifier circuit, a pair of Woofers/Midrange/Tweeters and Xover Network. The problem Is they have 4 ohms but I just want to test and analyze everything it was said here. I also have a pair of already made (comercial)8ohms enclosures, so I think that all the necessary stuff to test results and compare is available. Thanks everyone for the replies and as soon as I finish (and during...) testing I will be posting my results here. Greetings.
| Is there a rule of thumb for calculating the transormer's VA rating? | Bricolo | Solid State | 16 | 23rd June 2006 12:22 PM |
| Rule of Thumb on 3 way driver SPL's. | 2litre | Multi-Way | 4 | 15th September 2005 08:21 AM |
| Thumb Rule for determining Approx output power of class AB amp | rajeev luthra | Solid State | 12 | 3rd August 2004 07:34 PM |
| No. of parallel BJT? Rule of thumb? | sam9 | Solid State | 4 | 26th April 2004 10:48 PM |
