diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   balanced/unbalanced preamplifier (http://www.diyaudio.com/forums/chip-amps/126529-balanced-unbalanced-preamplifier.html)
Berry 17th July 2008 06:32 PM
2 Attachment(s)
What is the best schematic ?
If there are better one's please let me know. I wil use it for an aleph 5.
juma 20th July 2008 06:22 PM
Berry,
OpAmps are second choice parts for this job. To do it properly you need a fully differential amp (OPA1632,THS4131....)
leadbelly 20th July 2008 06:50 PM
First of all, this is the wrong forum for this thread. It should be in SS or Pass labs.
AFAIK, using a diff opamp will actually make a very mediocre phase splitter.
The best topology for phase splitting with opamps is this:
http://sound.westhost.com/p87-f3.gif
Which is what the inside of a DRV13x chip looks like.
HOWEVER, it is silly to use an opamp to do the splitting for an Aleph IMHO. The Aleph frontend should do a better job of phase splitting itself. If you absolutely need more gain I suggest you look at a discrete phase splitter.
juma 20th July 2008 10:09 PM
Try to compare directly (sound-wise) DRV134 to OPA1632 and you'll easily comprehend that DRV134 is by far inferior circuit.
I'm not willing to start a debate on this - just delivering commonly known fact.
gregorx 20th July 2008 11:37 PM
Have you taken a look at these:
THAT1646
Berry 21st July 2008 06:07 PM
Thank you all !
The reason i do not use an Aleph pre is because it does not fit in the nad T162. The NAD tuner/preamp has no balanced output.
I can use the power supply of the NAD to drive an op-amp, to build an balanced output.
Berry 21st July 2008 08:09 PM
2 Attachment(s)
Last question,
Is this the circuit to use to go from unbalanced to balanced ?
juma 22nd July 2008 08:58 AM
http://www.diyaudio.com/forums/showt...26#post1563426
digi01 24th July 2008 12:09 AM
i built the real thing.
bridge preamp
drv134 version
zang
Berry 8th August 2008 06:46 AM
I build the drv134 version, the problem that i have more noise than sound ?
The Amp for wich i will use it, is an aleph 5. When i put 2 capacitors in the + and the -, the noise dissapear. Why is it not possible to drive the aleph direct by the drv134 ?
Resources saved on this page: MySQL 18.75%
