balanced/unbalanced preamplifier
Old 8th August 2008, 08:42 AM   #11
could Jensen help?
http://www.diyaudio.com/forums/showt...48#post1580548
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th August 2008, 09:25 AM   #12
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by Berry
I build the drv134 version, the problem that i have more noise than sound ?
The Amp for wich i will use it, is an aleph 5. When i put 2 capacitors in the + and the -, the noise dissapear.
Why is it not possible to drive the aleph direct by the drv134 ?
I cant see why you cant drive Aleph 5 or any other power amplifier
directly from DRV134.
About putting caps, I suppose you mean SERIES Output caps.
When you have not a stable DC output 0 Volt level (some dc-offset)
you may need output caps to get it to work well.
You can try without caps, and try different levels sound output
while measure any DC-Voltage at those two DRV134 outputs.
If you get any substancial DC-Offset output,
you should use Output caps.
lineup
balanced/unbalanced preamplifierHide this!Advertise here!
Unbalanced to Balanced mcash257 Parts 3 14th October 2004 12:03 AM
Unbalanced - Balanced Tube Preamplifier wanted bebong Tubes / Valves 9 21st June 2004 05:32 AM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
unbalanced or balanced theturtle Everything Else 4 5th January 2003 04:52 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Copyright ©1999-2017 diyAudio
