Old 18th July 2008, 08:57 AM   #11
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Ted, your 10K attenuator will have 24 voltage dividers that consist of two resistors, one in series, and one to ground that divide the signal and shunt the unwanted part to ground.
The total value of the resistors in each pair will add up to the value of the attenuator - 10K (10,000 ohms) in your case.
If one of the resistor values is 100K as Peter points out from the picture of your attenuator, then the attenuator cannot be 10K.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 18th July 2008, 09:39 AM   #12
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
sorry i should have said, the picture is just a representation not the actual pot.
I have put a 1vp-p signal at 1kHz though the amp with the attenuator. The 'middle' steps really do almost nothing
Old 18th July 2008, 10:24 AM   #13
Ted205's Avatar
Putting the scope across the stepper just by itself is not much better either.
It must be a duff attenuator ?
Old 18th July 2008, 10:48 AM   #14
just take some rest ... then ... seat down ... then ... measure each restistance for each step ... then enter the values into excel and compare both channels with the resulting graph ... this all takes about 10 minutes to get an oversight about what you are holding in your hands ... and it let's you avoid troubles before you solder a part into a circuit
the truth is somewere
Old 18th July 2008, 11:39 AM   #15
Ted205's Avatar
here is a graph of the output resistance. As you can see steps 16-24 are wasted.
The sound is an improvement over a 'normal' pot so I will have to look out for another stepper
Old 19th July 2008, 11:44 AM   #16
you have the attenuator wired up wrong.
The return side should be common to both the input and output.
I think you have wired it up as a variable resistor instead of an attenuator.
regards Andrew T.
Old 19th July 2008, 01:21 PM   #17
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
It looks like input and output connections from attenuator are mixed up.
Attached is a graph showing proper way to a wire a pot. You can see that at lowest setting, the output resistance is zero and then goes up and the input resistance is fixed, equal to pot value.
If you wire your attenuator this way, it should work fine.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st July 2008, 02:10 PM   #18
Ted205's Avatar
i'm not sure its the wiring.
Steps 16->23 can be either 0ohms or 10ohms depending which way i put the input/GND as the only measurable varying resistance is the wiper (output)
diy stepped attenuator under 10$ kaushik Parts 23 12th January 2012 10:37 AM
Stepped attenuator sonokeling Parts 0 11th July 2006 09:05 AM
Stepped attenuator Bas Horneman Tubes / Valves 24 16th June 2004 07:18 AM
Stepped Attenuator officeboy Parts 3 6th May 2004 03:32 PM
Page generated in 0.10253 seconds (69.96% PHP - 30.04% MySQL) with 11 queries
